Really need help please
evie
Re: Really need help please
the only zips i know are the ones on clothes....
evie
Yeah, I tried clicking on it, it goes to word and won't open  Embarrassed
VileReynard
Fixes: 20
A rar file is a compressed container for other files - like .zip files, but better.
I think you should read this (I haven't got Windows BTW)  Smiley
http://support.microsoft.com/kb/827099
pierre_pierre
a zip file (that was the original generic name) is a compressed file or series of file, put into a much smaller space.
evie
okay, so is it poss. to unzip the file using XP, Pierre?
evie
i've tried open and repair - doesn't work...
pierre_pierre
I think that the Microsoft link suggested how to recover the ASD file and incorporate it into the word file
Looks like you have just tried that - or did your use the rar?
evie
yeah, i've followed those steps but it won't open....
MikeWhitehead
The ASD file extension is used for word automatic backup. Out of interest, what happens when you try to open the *.asd file (by going into Microsoft Word, then going to File > Open)? I'm sorry but I'm working a little blind here, I use OpenOffice so haven't had a lot of exposure to Microsoft Office lately.
EDIT: Sorry, just seen your replies. I'll be back after the second-half and we'll get you sorted Smiley
Santiago
If the second half is going to be like then first then I wouldn't bother
shutter
Fixes: 65
Try right clicking on the  .asd file  ..... you should get a notice  "open with"..... and then a list of possibilities.
If you have word or notepad listed, try them and see what happens....
evie
shutter, been there done that, doesn't work
santiago, thanks Smiley
mike, it says 'word experienced an error trying to open the file'
try these suggestions:
check file permissions
make sure there's enough memory
open with text recovery
shutter
Fixes: 65
Oh dear !.....  have sent you a PM  Wink
evie
LAdies and gents, thanks for your sterling work, the battle carries on, i'll be back later....any suggestions would be gratefully received
Thanks to all
evie
