Really need help please
- Re: Really need help please
26-06-2008 6:40 PM
26-06-2008 6:53 PM
quick query- the file had a name and everything and it was saved on desktop, what do you mean by 'same directory'?- the latest version wasn't on desktop.
26-06-2008 6:56 PM
Quote from: evie axis of evil- you really know how to kick someone when they're down-don't go into counselling will you- the tips would have been appreicated more, if they'd come without the barbs. thanks nonetheless
Thats just how he is. What he has suggested is really good practice that you should take on board . I know you are hurting from losing your work and frustrated that you can't recover it yet. It has happened to most of us I guess
26-06-2008 6:57 PM
26-06-2008 7:27 PM
If it was an XP disc look in Documents and settings, then your user name, then desktop
26-06-2008 7:33 PM
The easiest method of getting to the desktop is %SystemDrive%\Docume~1\%Username%\Desktop
(why look solely on the Desktop when you can search the entire drive?)
26-06-2008 7:42 PM
anyway, i', trying what you told me, be back in a tick, thanks a lot for your advice, greatly appreicated.
26-06-2008 7:45 PM
26-06-2008 7:53 PM
file is called: autorecovery save of xxx. rar
any ideas?
26-06-2008 8:00 PM
26-06-2008 8:02 PM
26-06-2008 8:18 PM
enjoy the footy, mike, thanks for your help so far.
26-06-2008 8:25 PM
before you do anything Make a note of the files it's location, it's creation/update date/time, what created etc.
Sorry for the hard advice I gave earlier - but nearly everyone has to learn the hard way!
26-06-2008 8:26 PM
But XP has a built in zip expansion, have you just tried to open it - you might find that works
26-06-2008 8:28 PM
it now says it's an 'asd' file- i have no idea how it went from rar to asd. bitzipper is refusing to open it when i select it now.
