Re: VMWare Server and CD-ROMS
The_10th
Thanks for the info.
Are you saying that you have to cancel VMware tools all the time to access the CD Drive and then re-install to boost performance?
6 REPLIES 6
VileReynard
Fixes: 20
Well - I've never even looked at VMWare - as is apparent:-
Is the scenario where you load X-windows an instance where you are using VMWare in a Linux environment to run another *nix style environment?
Why would you want to bother installing X-Windows into a Windows environment?
chillypenguin
Quote from: PJ
In Linux you will probably want to get a x-window service running so that you can install it using the package manager.
Wuss, what's wrong with using the command line.
rpm -Ivh vmtools.rpm
grimme
@PJ
Have you by any chance made any comparisons between vmware and virtualbox?
I have used virtualbox with a Windows XP host and have tried both an Ubuntu guest and a Mint guest. It seemed very easy to setup and not too slow using the guest OS.
I've not used vmware and wondered how it might compare to virtualbox.
VileReynard
Fixes: 20
VMWare - see http://en.wikipedia.org/wiki/Vmware
http://en.wikipedia.org/wiki/Virtual_machine includes a list (and links) to lots of VM's.
The_10th
Quote from: PJ
well VMWare Server is free ...
So is Virtualbox though. From what I have tried VBox seems less complicated to setup.
7up
Fixes: 17
I tried VMServer once but didn't like it as I found the mouse emulation to be a bit on the sluggish side.
I switched back to VMPlayer which is far more responsive (especially when you log into the VM via Remote Desktop :D).
Apparently though, I'm one of the few people who ever experienced this odd phenomenom.
