Re: Free Security Software - Split off at the request of the OP
KenA
Quote from: Midnight
If you are reading this you are on the Internet, and as such you need Security Software for your computer, the Security Software you should have on your computer is: Firewall plus Anti-Virus at least on your computer.
Nope, I'm running linux!
VileReynard
Seasoned Pro
Fixes: 11
(Windows only).
A router firewall is probably quite sufficient for Linux.
I wonder why M$ don't bother to supply a virus checker - or even prevent them from "infecting" in the first place?
Fixes: 62
Two points
First - which forum is this in - Microsoft Windows
Second - who do you think provides Microsoft Security Essentials which is an antivirus
Fixes: 62
Please note that the original thread is in the Microsoft Windows Section
VileReynard
Seasoned Pro
Fixes: 11
Re: [Windows] - Free Security Software
So the Windows anti-virus requirement is a security hole.  Cheesy Cheesy Cheesy
Fixes: 247
Re: Re: Free Security Software - Split off at the request of the OP
I don't have any AV on my Mac but I don't feel the need to bleat about it on every thread.
Linux is still not ready for the vast majority of users...
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
VileReynard
Seasoned Pro
Fixes: 11
Quote from: adiewoo
I wasn't bleating - or even mentioning - that Linux is fully ready for any user Smiley
That would have been off-topic - wouldn't it?
VileReynard
Seasoned Pro
Fixes: 11
Which one was that?
Fixes: 62
see Post 4
