Re: AGP graphics cards
Fixes: 10
As I said in messenger to you there are physical differences.
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port looks a useful read as it has a section on compatibility and the different voltage keying.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
1 REPLY
Yes.
There are 3 versions of AGP, each with its own voltage, and 4 or 5 versions of AGP slots and it really depends on which version slot/AGP version the Mobo supports as to whether the 8X card will work.
See AGP Compatibility for info on the different standards and even more different AGP card slots.
