Rate windows 10
St3
Aspiring Champion
Fixes: 5
Rate windows 10
Ive had windows 10 for 24 hours and MS sent me an e-mail asking me to review it lol ..... Give me 12 months atleast ffs 😜
5 REPLIES 5
rongtw
Fixes: 12
Re: Rate windows 10
lol yes ste
after months on insider i would say 8/10 still has some work needed
Strat
Fixes: 565
Re: Rate windows 10
Agreed...I'm having issues with sound for example.
the_groundsman
Re: Rate windows 10
It's much more annoying than i was anticipating. Edge seems slow and doesn't load some sites. I've had problem with my microphone so Skype is not working for me - its integrl with the webcam which does work. i  thought it was going to be easier.
pjmarsh
Fixes: 19
Re: Rate windows 10
I had one last night, but it was asking me to rate and feedback on the upgrade process.  Are you sure it wasn't the same one that you got?
alanf
Re: Rate windows 10
The one I just got was also specifically about the upgrade process not the experience of W10 after the upgrade had completed.
