Raspberry pi: lcdproc + mpdlcd control scroll speed?
HairyMcbiker
All Star
Fixes: 21
Anybody got any hints on slowing down the scroll speed when using lcdproc + mpdlcd ?
On my blue 2 line lcd the text is just a blur, tried changing all the settings in lcdproc.conf (and restarting it) but still the same.
15 REPLIES 15
Re: Raspberry pi: lcdproc + mpdlcd control scroll speed?
@HairyMcbiker - What value is the setting you have for the TitleSpeed = ?
Edit:- You want something between 0 (No Scoll) and 10 (No Delay)
HairyMcbiker
All Star
Fixes: 21
I went from 1 to 7 at random increments.
OK what does :
find / -type f -iname 'lcdproc.conf'
I'm asking just in case you're making changes to another copy of the file that's not in scope for your project.
HairyMcbiker
All Star
Fixes: 21
root@volumio:/home/volumio# find / -type f -iname 'lcdproc.conf'
/etc/lcdproc.conf
That's fair enough, are their any entries in its log file, try changing the value to a char value to break it, if this doesn't generate an error then check the case and structure of the settings, I suspect they may well case sensitive, and is it x=y or x y or x: y etc.
HairyMcbiker
All Star
Fixes: 21
@Anonymous I can't find any log file for lcdproc
The layout is the same as the rest of the file, and what was stated on the web page.
TitleSpeed=1
With that I can just read the text when it stops to reverse.
Will try changing the value and see if I get any errors anywhere
EDIT: weird lcdproc doesn't appear to be running, BUT killing mpdlcd shows the lcdproc screen!
root@volumio:/home/volumio# killall mpdlcd
root@volumio:/home/volumio# killall lcdproc
lcdproc: no process found
@HairyMcbiker, can you tell me what method you're using to display your data please.
Edit:- The server is called LCDd.
HairyMcbiker
All Star
Fixes: 21
@Anonymous
OK found the server process LCDd!
What method?
I am running volumio, mpdlcd connecting to mpd to read the playing item and display it. That's it.
changing TitleSpeed to "a" does nothing, as does setting to 0 which should halt the scroll.
HairyMcbiker
All Star
Fixes: 21
OK it looks like TitleSpeed=1 in the LCDd.conf as well does nothing.
From further investigation mpdlcd talks directly to LCDd not using lcdproc (so lcdproc.conf is a red herring)
@HairyMcbiker - This sounds to me like its actually related to the library you're using for the LCD, have a look at the docs to see how to reduce the scroll speed.
HairyMcbiker
All Star
Fixes: 21
@Anonymous
OK got it!
in the mpdlcd.conf
"pattern2 = {song format="%(artist)s",speed=4} {elapsed}
{song format="%(title)s",speed=5} {state}"
the 2nd line speed was 2 which is FAST changed to 5 and it is readable.
There is NOTHING in the docs about this!
7up
Fixes: 17
HMcB when are you going to post us a photo of what i assume is some super grand man lab?
Actually.. thats a good idea for a new topic..
HairyMcbiker
All Star
Fixes: 21
Wouldn't I love it if it was a "super grand man lab" !
At the moment it is a dumping ground with just enough room for the 3 monitors (2 on this pc, 1 for the current pi I am working on) to rest on swivel arms. Filled with printers (4 of them! 1 I use all the time a b&w laser, my trusty ip5000, and switched off a clp500 and a large canon mpd (most of them I got off freecycle) , hops, electronic bits, tall freezer, etc etc.
I keep saying one day I am going to have a clear out and get rid of some of this rubbish (as SHMBO calls it)
7up
Fixes: 17
Ha! Similar to me then. My trusty old konica minolta coiour laser is out of action too. Some internal component has finally run out (can't remember which one though lol).
I got a small desk (forcefully downgraded by the missus when we moved to a bigger place - cos that just makes total sense) so i don't have any space for doing anything really... i have use of the garage.. with no power supply.. so thats full of other junk i've collected lol.
