Raspberry pi dns server
- Re: Raspberry pi dns server
21-06-2013 6:27 PM
cd /etc/bind/raspberrydns
sudo ./bind9BadDomains.py
Please note the Python script takes about 10mins to complete on the Raspberry Pi, obviously its much quicker on more meatier processors. Once done you’ll have a nice big juicy file called: named.conf.blocked.new. To get this in the right place and restart Bind9 to take all the above changes into account, just run the Bash script:
sudo ./update.sh
21-06-2013 6:33 PM
21-06-2013 7:00 PM
Otherwise try sudo python <script>
24-06-2013 4:44 PM
I can't get it to work at all, i just keep following the instructions from the link above line for line.
driving me mad
Make a copy of the interfaces file:
sudo cp /etc/network/interfaces /etc/network/interfaces.orig
Now edit the interfaces file:
sudo nano /etc/network/interfaces
Comment out the line, prefix with a #:
#iface eth0 inet dhcp
Paste the following - note in my network I’m setting my Pi server to 192.168.1.5:
auto eth0
iface eth0 inet static
address 192.168.0.15
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.254
dns-nameservers 127.0.0.1
dns-search home.lan
dns-domain home.lan
(My router has the IP address of 192.168.1.1, I’m sure the rest is easy to work out from the above. I’ll explain home.lan later..)
Ctrl + x to save, and reboot the Pi.
Using Terminal on your computer ssh into the Pi - follow the instructions as they come up:
ssh pi@192.168.1.5
Raspberry Pi - DNS Server Plans - part 3
Part 3 (which is the final part to this series) covers off installing your home DNS server and configuring it to block iffy websites and adverts in a direct effort to improve security and general internet safety.
Install DNS Service - Bind9
I’m using Bind9 as it’s well used on the internet and there’s plenty of help for it. I want to set it up so all my network devices on my home network use this service to lookup domain names - at this point I can block undesirable addresses. I’ve use this guide as inspiration: http://www.learnlinux.co.uk/E/technical_notes/ln0008.htm
Install bind service on the Pi - just follow the instructions:
sudo apt-get install bind9
Backup everything first:
cd /etc/bind
sudo cp named.conf.options named.conf.options.orig
sudo cp named.conf.local named.conf.local.orig
sudo cp named.conf.default-zones named.conf.default-zones.orig
Create a new database file for HOME.LAN items. This will contain all the fixed IP names on the network - for example my router is at 192.168.1.1 and this Raspberry Pi is at 192.168.1.5.
sudo nano db.home.lan
Paste:
; Use semicolons to add comments.
; Host-to-IP Address DNS Pointers for home.lan
; Note: The extra “.” at the end of the domain names are important.
; The following parameters set when DNS records will expire, etc.
; Importantly, the serial number must always be iterated upward to prevent
; undesirable consequences. A good format to use is YYYYMMDDII where
; the II index is in case you make more that one change in the same day.
home.lan. IN SOA raspberry.home.lan. hostmaster.home.lan. (
2008080902 ; serial
8H ; refresh
4H ; retry
4W ; expire
1D ; minimum
; NS indicates that raspberry is the name server on home.lan
; MX indicates that raspberry is (also) the mail server on home.lan
home.lan. IN NS raspberry.home.lan.
home.lan. IN MX 10 raspberry.home.lan.
; Set the address for localhost.home.lan
localhost IN A 127.0.0.1
; Set the hostnames in alphabetical order
raspberry IN A 192.168.0.15
router IN A 192.168.0.254
Now we create a reverse lookup database file for our HOME.LAN fixed IP’s
sudo nano db.rev.0.168.192.in-addr.arpa
Paste:
; IP Address-to-Host DNS Pointers for the 192.168.0 subnet
@ IN SOA raspberry.home.lan. hostmaster.home.lan. (
2008080902 ; serial
8H ; refresh
4H ; retry
4W ; expire
1D ; minimum
; define the authoritative name server
; our hosts, in numeric order
1 IN PTR router.home.lan.
5 IN PTR raspberry.home.lan.
Create a new file to direct all blocked domains. This database file returns an IP address of 127.0.0.1 for all domains directed to it, and thus blocking all web requests.
sudo nano db.blocked
Paste
; BIND db file for ad servers - point all addresses to localhost
$TTL 86400 ; one day
2004061002 ; serial number YYMMDDNN
28800 ; refresh 8 hours
7200 ; retry 2 hours
864000 ; expire 10 days
86400 ) ; min ttl 1 day
A 127.0.0.1
* IN A 127.0.0.1
We now need to update the main bind config file, just a little configuration changes. Start with the Options file:
sudo nano named.conf.options
Now for me OpenDNS provides the best speeds over Google DNS, but that’s because I’m in the UK. Find the forwarders section and insert the OpenDNS settings:
forwarders {
212.159.6.9;
212.159.6.10;
Second Options file tweak is the following, can’t remember for the life of my why, but I read this somewhere and it works well. Ensure these are present in the file:
dnssec-enable no;
dnssec-validation no;
Our two new database home.lan files need to be included in the bind9 system configuration, (This will pick up every home.lan domain request on your network), so edit:
sudo nano named.conf.local
Paste:
zone "home.lan" IN {
type master;
file "/etc/bind/db.home.lan";
zone "0.168.192.in-addr.arpa" {
type master;
file "/etc/bind/db.rev.0.168.192.in-addr.arpa";
Finally, all the named files need to be brought together, so edit:
and I just include the following files
include "/etc/bind/named.conf.options";
include "/etc/bind/named.conf.local";
include "/etc/bind/named.conf.blocked";
Hang on! What’s this named.conf.blocked file?? Well, I’ve written a Python script to generate this file. It works by downloading lists of iffy domains from two wonderful sources: http://winhelp2002.mvps.org & http://malwaredomains.com. It works by directing all domain requests each iffy website to our db.blocked file. For example:
zone "x0.nl" {type master; file "/etc/bind/db.blocked";};
zone "sp.sk" {type master; file "/etc/bind/db.blocked";};
zone "51.la" {type master; file "/etc/bind/db.blocked";};
Also, I’ve added functionality to the script, to take into account manually specified domains from a local file called: manualDomains.txt. In my file I’ve added the TLDs RU and CN to totally block Russian and Chinese domains from all devices on my network.
This sounds great - how do it get my hands on a copy? I’ve put all the code into a GIT repository, so you’ll need to install git first:
sudo apt-get install git
Pull down all the Python code and files:
cd /etc/bind
sudo git clone https://figsternet@bitbucket.org/figsternet/raspberrydns.git
This creates the directory /etc/bind/raspberrydns which contains one Python script, one Bash script and a few text files.
To re-generate the names.conf.blocked file with the latest information from malwaredomains.com etc, just type the following :
sudo ./update.sh
And that’s it really for the Pi side of things. Obviously you’ll want to test this, so in a terminal session on a different computer type the following:
dig @192.168.0.15 google.co.uk
You should see a large list of information here, but at the bottom there will be two lines of interest :
;; Query time: 149 msec
;; SERVER: 192.168.1.5#53(192.168.1.5)
24-06-2013 5:53 PM
Successfully flushed the DNS Resolver Cache.
C:\Users\Laptop>nslookup
Default Server: UnKnown
Address: 192.168.0.15
> bbc.co.uk
Server: UnKnown
Non-authoritative answer:
Addresses: 212.58.253.67
212.58.251.195
pi@raspberrypi /etc/bind/raspberrydns $ sudo /etc/init.d/bind9 stop
[....] Stopping domain name service...: bind9rndc: connect failed: 127.0.0.1#953: connection refused
. ok
pi@raspberrypi /etc/bind/raspberrydns $ sudo ./bind9BadDomains.py
Start: 2013-06-24 16:24:08
Downloading...
Original: 31119
Processed: 22816
Duplicate: 8303
End: 2013-06-24 16:35:04
pi@raspberrypi /etc/bind/raspberrydns $ sudo ./update.sh
Copy existing named.conf.blocked file to backup
cp: cannot stat `/etc/bind/named.conf.blocked': No such file or directory
Stop the DNS service
. ok
Copy the new files into place
mv: cannot stat `/etc/bind/named.conf.blocked': No such file or directory
Start the DNS service
[ ok ] Starting domain name service...: bind9.
Flush the DNS cache
Done...
now i'm getting thousands of this error....
Jun 24 16:36:24 raspberrypi named[3119]: zone acvs.mediaonenetwork.net/IN: not loaded due to errors.
Jun 24 16:36:24 raspberrypi named[3119]: /etc/bind/db.blocked:2: no current owner name
Jun 24 16:36:24 raspberrypi named[3119]: zone acvsrv.mediaonenetwork.net/IN: loading from master file /etc/bind/db.blocked failed: no owner
Jun 24 16:36:24 raspberrypi named[3119]: zone acvsrv.mediaonenetwork.net/IN: not loaded due to errors.
Jun 24 16:36:24 raspberrypi named[3119]: zone mediastat.net/IN: loading from master file /etc/bind/db.blocked failed: no owner
Jun 24 16:36:24 raspberrypi named[3119]: zone mediastat.net/IN: not loaded due to errors.
Jun 24 16:36:24 raspberrypi named[3119]: zone mediaxsds.net/IN: loading from master file /etc/bind/db.blocked failed: no owner
Jun 24 16:36:24 raspberrypi named[3119]: zone mediaxsds.net/IN: not loaded due to errors.
Jun 24 16:36:24 raspberrypi named[3119]: zone mediazones.net/IN: loading from master file /etc/bind/db.blocked failed: no owner
/etc/bind/db.blocked:3: no current owner name
loading configuration from '/etc/bind/named.conf'
/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no current $ owner nameJun 24 15:24:33 raspberrypi named[2294]: reading built-in trusted keys from f$
I'm at a loss..
24-06-2013 5:56 PM
Jun 24 15:24:28 raspberrypi named[2294]: ----------------------------------------------------
Jun 24 15:24:28 raspberrypi named[2294]: BIND 9 is maintained by Internet Systems Consortium,
Jun 24 15:24:28 raspberrypi named[2294]: Inc. (ISC), a non-profit 501(c)(3) public-benefit
Jun 24 15:24:28 raspberrypi named[2294]: corporation. Support and training for BIND 9 are
Jun 24 15:24:28 raspberrypi named[2294]: available at https://www.isc.org/support
Jun 24 15:24:28 raspberrypi named[2294]: adjusted limit on open files from 4096 to 1048576
Jun 24 15:24:28 raspberrypi named[2294]: found 1 CPU, using 1 worker thread
Jun 24 15:24:28 raspberrypi named[2294]: using up to 4096 sockets
Jun 24 15:24:28 raspberrypi named[2294]: loading configuration from '/etc/bind/named.conf'
/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no current owner name/etc/bind/db.blocked:3: no curre$
Jun 24 15:24:33 raspberrypi named[2294]: using default UDP/IPv4 port range: [1024, 65535]
Jun 24 15:24:33 raspberrypi named[2294]: using default UDP/IPv6 port range: [1024, 65535]
Jun 24 15:24:33 raspberrypi named[2294]: no IPv6 interfaces found
Jun 24 15:24:33 raspberrypi named[2294]: listening on IPv4 interface lo, 127.0.0.1#53
Jun 24 15:24:33 raspberrypi named[2294]: listening on IPv4 interface eth0, 192.168.0.15#53
Jun 24 15:24:33 raspberrypi named[2294]: generating session key for dynamic DNS
Jun 24 15:24:33 raspberrypi named[2294]: sizing zone task pool based on 22823 zones
Jun 24 15:24:47 raspberrypi named[2294]: set up managed keys zone for view _default, file 'managed-keys.bind'
Jun 24 15:24:47 raspberrypi named[2294]: Warning: 'empty-zones-enable/disable-empty-zone' not set: disabling RFC 1918 empty zones
Jun 24 15:24:33 raspberrypi named[2294]: reading built-in trusted keys from file '/etc/bind/bind.keys'
Jun 24 15:24:47 raspberrypi named[2294]: automatic empty zone: 254.169.IN-ADDR.ARPA
Jun 24 15:24:47 raspberrypi named[2294]: automatic empty zone: 2.0.192.IN-ADDR.ARPA
24-06-2013 6:36 PM
24-06-2013 6:39 PM
And Adblock does the same job on FF. My youtube doesn't even show the "cant find" box.
24-06-2013 7:06 PM
but i can confirm it is working, just not as i would like. I need to invest more time into understanding it, google hasn't presented me with an easy fix thus far.
it seems to speed stuff up no end with half the crap blocked, sites like bbc.co.uk load really fast. I did mean to try out npr's unbound but i've not got around to that yet, i guess it is the same sort of thing.
Does anybody have idea's on how safe this is to use full time running properly ?
I've used Adblock before but i was looking for a more wide deployment of blocking for my pads etc.
24-06-2013 8:36 PM
25-06-2013 9:51 AM
25-06-2013 10:17 AM
have done it on a pi yet, but it's something i might try.
01-07-2013 3:10 PM
dnssec test http://dnssec.vs.uni-due.de/
08-07-2013 6:38 PM
Next project... Unbound. I must be a sucker for punishment.
20-07-2013 1:38 PM
Well i am surprised in all honesty, Unbound works perfectly and does what i need it to do with no nonsense or fuss. yes it cost me 30 quid or so but well worth the price for better control imo. Installing unbound was very simple on the raspberry pi using npr's tutorial http://npr.me.uk/pidns.html i'm also using opendns and add-blocking which works very well indeed for a small network with fast game machines that are constantly needing to resolve in large volume which will be constant for the summer holidays, for which i think we are well prepaired for now. All info on installing Unbound is covered on npr's website along with add-blocking and dnssec etc. here is a dnssec test http://dnssec.vs.uni-due.de/ Many thanks again to npr for the tireless info he provides, and also the personal help and input on using opendns forwarders on this project which i've added below. Should you need to use your own forwarders etc, you would just type those few lines at the bottom of your unbound.conf file obviously changing the ip address to those you prefer. Below i have added a few sites i found usefull to me on this project.
forward-zone:
forward-addr: 208.67.222.123
forward-addr: 208.67.220.123
https://calomel.org/
http://www.unbound.net/documentation/howto_statistics.html
http://www.debuntu.org/how-to-monitoring-a-server-with-munin/
