Rapidshare downloads
esseff
I've noticed over the last few days that a single off-peak RS download seems to be capped at 1mb/s. Can anyone confirm this, as it's my experience, and has it anything to do with the traffic issues going on at the moment?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Rapidshare downloads
On your account type, downloading from download sites are restricted between 4pm and midnight down to 512kbs. Take a look here for more detail: http://www.plus.net/support/broadband/products/archive/broadband_premier_archive.shtml
 Chris Parr
 Plusnet Staff
esseff
Hi Chris
I did say OFF-peak. Which means upto 4pm is when I'm seeing the issue.
Plusnet Staff
Plusnet Staff
Fixes: 159
Sorry, missed that completely!!
Today would have most likely been caused by the traffic management issues, however these have only been occurring today so anything prior wouldn't have been.
 Chris Parr
 Plusnet Staff
esseff
No Probs.  Smiley
It's been happening for a several days now.
Are you saying there's nothing in place to cause this to happen that you know of?
It's too close to the same figure each time to be anything but throttled.
If I download 2 files at the same time, I get close to my full line speed of 2 mb/s. I don't always have more than one to download though. So something is definitely getting in the way.
esseff
a bit more info.
The change seems to take place at around 8.00am. Before 8, I can download a single file at full speed, after 8 (i just thought of chocolate mints) the throttling comes in. As my off-peak continues after 8, there might be something applied to my profile that shouldn't be there.
Having said that. If there was throttling going on, it wouldn't matter how many files i downloaded at the same time, I probably wouldn't get line speed. So that doesn't necessarily make sense. I'm confused  Huh
Plusnet Staff
Plusnet Staff
Fixes: 159
Do Rapidshare have restrictions on the speed you can download items from them? I know some download sites only allow Xkbps unless you pay for premium accounts.
 Chris Parr
 Plusnet Staff
esseff
I have a premium account with them, and no, download speeds are way more than I can reach.
