Rant - Windows hiding things
- Rant - Windows hiding things
29-01-2010 3:50 PM
A file was opened from an email and modified and saved using the save button.
Where was it saved - in a folder called Temporary Internet Files / Content IE5 / "some random letters"
Can you see the folder - not without a great deal of fiddling as explorer doesn't see it as it is permanently hidden.
To actually get to it I had to use the Disk Cleanup Utility - now how stupid is that
Re: Rant - Windows hiding things
29-01-2010 4:28 PM
Another little Microsoft foible I've tripped over many times.
I've just got into the habit of using 'Save as' as a way around the problem. Still very frustrating though
M
02-02-2010 1:06 PM
04-02-2010 5:44 PM
Quote from: Denzil ....t had been opened in the background where I couldn't see it ::).
Yes, that's a common problem. It is often made worse if you have logged in via remote desktop.
04-02-2010 6:31 PM
05-02-2010 11:21 AM
Quote from: HPsauce There's normally a clue in the Taskbar.
Sometimes - but not always?
