Range extender printing issue
Rodc14
Hi All,
Just connected a tplink wa701nd range extender to the plusnet hub.  Works fine except Ipad cannot print to Hp printer using Hp Smart app when connected via extender.  No printing issue when range extender is off.   Can't find any settings that might resolve this.
Would appreciate any help with this.
Rod
5 REPLIES 5
Gel
Aspiring Champion
Fixes: 29
Re: Range extender printing issue
Has the extender got same ssid as router?
Try changing extenders to something different & see if your pad software finds it.
Fixes: 1,482
Moderators Note.
Moved to tech help as it's not an issue with OP's broadband.
Rodc14
Yes same ssid can get internet access via extender,  Just came print using ipad when connected via extender.  Ipad printing works fine when i switch off the extended?!
Rodc14
Ps.  The set up of the extender only ask for ssid and mac address of the'root AP'.  It does not have a field for an alternative ssid for the extender.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
Gel
Aspiring Champion
Fixes: 29
You may need to ferret around; it may be in ADVANCED SETTINGS or something similar.
My TP Link certainly has it.
