Ram Speed Issue?
- Re: Ram Speed Issue?
Ram Speed Issue?
11-05-2009 11:05 AM
On a new build I have a pair of matched ram sticks. The sticks (OCZ2T1066IO1G)state they should run at 5.5.5. 2.1v
I haves used bios settings to set them up at 5.5.5.15 2.1v and all seems to be ok with no memtest failures or blue screens but something is nagging me that I would like your opinion on.
If I run any utility such as Everest. Easy Tune etc
They all show that one stick is running at 333 5.5.5.15 and the other at 270 4.4.4.13
Does this matter? Shouldn’t the BIOS setting force them both to the same speed?
5 REPLIES 5
11-05-2009 12:40 PM
They should be both at the same speed.
I am now going to sound very patronising - sorry - but you did put the ram in the correct slots so that they work in dual mode and not independantly
There is another possibility - but I have no idea how it could happen - and that is the automatic load system is backing one stick off more than the other.
One way to check is to manually overclock the motherboard by a very small amount - this will usually stop the automatic system working
Also have a read here http://www.avforums.com/forums/hard-drives-memory-ram-cards-sticks/952126-running-2-different-ram-mo...
11-05-2009 1:28 PM
Hi Jim
I have them running in slot one and three but it might be worth swapping them to two and four to see if it changes anything. I suppose the other thing to try is to swap the modules in the same slots and see if they rotate speeds or not.
It’s a gigabyte board and the slots are colour coded so I am fairly sure they are right. I did once have a problem on another machine where ram stability was bad in one set of slots but not the other.
Peter
Peter
11-05-2009 1:35 PM
Peter,
looking at my Gigabyte manual GA-P35-DS4 it states
One place to raise it is the OCZ support forum http://www.ocztechnologyforum.com/forum/index.php
I wonder if one of the memory chips isn't what it says it is.
Quote When memory modules of different capacity and chips are installed, a message which says
memory is operating in Flex Memory Mode will appear during the POST. Intel® Flex Memory
Technology offers greater flexibility to upgrade by allowing different memory sizes to be
populated and remain in Dual Channel mode/performance.
11-05-2009 2:12 PM
It is showing as dual channel interleaved, no mention of flex mode. I will raise it on the OCZ froum (as soon as they send a confirmation email!). Thanks for your help Jim.
All the best
Pete
All the best
Pete
11-05-2009 4:45 PM
Hi Jim
I have the answer, they were running at the same speed! I am afraid I was confusing the Everest reporting of the SPD tables as a report of the two sticks running at different speeds.
Cheers
Peter
Cheers
Peter
