Ram Advice ( solved )
Steve
Seasoned Pro
hi folks hope you are all well. I pulled out a pc from the cupboard and I couldn't believe I could run Linux Mint 17.2 cinnamon version on it without any problems! It doesn't find my integrated Radeon 3000 graphic card but its seems just fine running on Linux without it.
The other pc is now stuck in the cupboard lol ( has 17.2 mate ) on it. This pc has 1.7gb usable ram though so want a bit more ram. I'm running 32 bit so I know the pc will only see 4gb Max ram. Question is what ram do I need guys? I think I know but want to double check with someone knowledgeable;e here if possible.
I ran in the terminal ( sudo lshw -html >mySpecs.html ) fab command saves your specs to html file Smiley got this from it
id:
bank:1
description: DIMM DDR3 Synchronous 1066 MHz (0.9 ns)
product: M378B5673FH0-CH9
vendor: Samsung
physical id:
1
serial: 2D557163
slot: DIMM4
width: 64 bits
clock: 1066MHz (0.9ns)
This is the pc  http://support.hp.com/au-en/document/c02568761
and this link is the memory I think I'm buying  http://www.mrmemory.co.uk/memory-ram-upgrades/compaq/desktop/sg3-110uk-m
pc in cupboard is sadly DDR2. One last thing is it best to keep the ram matched? or could I just buy a 2gb stick to go with the current 1.7gb?
Thanks.
If life gives you lemons, make lemonade.
8 REPLIES 8
Oldjim
Fixes: 63
Re: Ram Advice
have you tried Crucial for a compatibility check
Steve
Seasoned Pro
Re: Ram Advice
I cant do a compatible check on crucial Jim it wont run on the pc. I think there is a script I can run but I'm not sure so not doing it.
Oldjim
Fixes: 63
Re: Ram Advice
I didn't mean that one - I meant doing it manually via motherboard reference
Steve
Seasoned Pro
Re: Ram Advice
Well this is the motherboard
id:
core
description: Motherboard
product: 2AAF
vendor: FOXCONN
physical id:
0
version: 1.00
But on the manufacturer website it says
Manufacturer: Foxconn
Form factor: uATX
Chipset: AMD 760G
Memory sockets: 2 x DDR3
Front side bus speeds: 5200 MT/s
Processor socket: AM3
Expansion Slots: 2 PCI Express x1 slots
Oldjim
Fixes: 63
Re: Ram Advice
The motherboard is probably the A76ML or the A76GMV but you really need to check the actual reference
Steve
Seasoned Pro
Re: Ram Advice
Thanks Jim I will do my best
Edit: Found the ram I need 2 x 240-pin DDR3 DIMM slots – Dual Channel DDR3 1333/1066 MHz non-ECC, un-buffered memory
HairyMcbiker
All Star
Fixes: 21
Re: Ram Advice
So you could put a 2Gb on 4Gb useable, or a 4Gb for 6Gb and install a 64bit OS on it.
Steve
Seasoned Pro
Re: Ram Advice
Yeah I was going to put 64 bit on it but not until I decide how much ram to get.
