Raising a Ticket
lordhitch
Raising a Ticket
Hi All, can anybody guide me to link so I can raise a good old fashioned "TICKET"
Need advice on Router interuptions logfile.
What to do ?
3 REPLIES 3
Oldjim
Fixes: 63
Re: Raising a Ticket
Ask on here - as you have done
Tickets are essentially finished for most problems
But from the log - and I am not an expert - the router firewall blocked an incoming request either because it was unsolicited or it was too long after the outgoing request
cedlor
You can check on Whois  where they are from - the two yellow ones are Microsoft  and some of the red ones are from Russia.  I get a lot from China and Russia- they are not usually anything to worry about as it is just telling you the firewall has stopped them.
Are you running Windows 10 perhaps?
Chris
Legend
Fixes: 169
The router firewall has stopped them and as they are spread out and not hitting every few seconds I wouldn't worry about them too much, pretty much every router log will have something like that showing at some point.
