Radio aerials - will this work?
pimpernel
If I were to connect an FM aerial and a DAB aerial to a diplexer and connect the single coax from the other side to a DAB/FM tuner, would the tuner work as good as I hope it would on both FM and DAB?
The tuner only has 1 F-plug connector and I already have the 2 aerials.
I am aware there is a combined FM/DAB aerial setup.
The tuner is a Tibo TI420
2 REPLIES 2
198kHz
Fixes: 41
Re: Radio aerials - will this work?
Assuming the diplexer was designed for those bands, it seems like the best solution as there's only one socket on the tuner.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
pimpernel
Thanks for that.
Have been investigating further and have found a specialist aerial web site.
Will ask them first for their recommendation.
