REGZOOKA Registery Cleaner
- REGZOOKA Registery Cleaner
09-07-2009 12:52 PM
Re: REGZOOKA Registery Cleaner
10-07-2009 1:46 PM
Have to say perfect optmizer has now updated to next version but seem far less effective than previous one.
However am also now using Windows Vista in built Disk Clean up and very slowly learning my way around the registry despite paying out for a lifetime subscription to Optimizer.
NB Perfect Optimizer is huge though for my laptop at around 450MB in size.
Best thing I did thanks to many helpful people on here was get rid of McAfee and use an alternative antivirus. Norton I believe is similar though slightly better in the size department.
My dad had used REGCURE and likes that.
10-07-2009 11:37 PM
Quote from: gillandkeith They claim its 100% effective (guaranteed)
That's a big claim.
Haven't used that one, but can recommend <a href="http://www.ccleaner.com/">CCleaner</a> and <a href="http://www.abexo.com/free-registry-cleaner.htm">Abexo</a>.
11-07-2009 8:21 PM
It's the one that's 100% non-destructive.
DM
12-07-2009 6:07 AM
Now I use CCleaner and it has always been OK, although I know that it is considered a mild reg cleaner.
I also use Revo Uninstaller in moderate mode when I take stuff off so this lessens the number of orphaned registry entries.
Although it is a bit more hassle, if things are getting gummed up I prefer a good clean reinstall and start all over again.
14-07-2009 8:15 AM
14-07-2009 12:53 PM
15-07-2009 7:03 AM
CCleaner has quite a good reputation amongst the bunch, if you want to try one.
05-08-2009 8:05 PM
05-08-2009 9:19 PM
Am working now on a laptop that I have just reformatted and it is better than new because I don't have all the rubbish software trials to contend with.
I know that it is a pain as it takes so long but well worth it in the end.
