RE: Anyone know what this is?
Anyone know what these are attached to the telegraph pole outside my house?
There are 4 little circular dishes - 2 directed upwards and 2 horizontal.
Looks like they are connected to the black box above with writing on. Not sure what the writing says. Could be TTCKV???
Any ideas?
Thanks.....
8 REPLIES 8
Re: RE: Anyone know what this is?
Not sure how to add multiple attachments, so heree are other pics...
Legend
Fixes: 255
@Anonymous  - You've already asked this question. Posting the same question/subject on multiple boards is against forum rules.
Sorry John...new to forum stuff so will delete this one.....Thanks...
Sorry - how do I delete this thread on here?
Thanks.
Legend
Fixes: 255
You don't - but a moderator might spot it and lock it.
marcyd
Its a fibre end box used in the rollout of FTTPod
Fibre to the premises od demand
Have a look here https://www.westlittleton.com/FastBroadband.php
RobPN
Fixes: 13
Regarding the 'circular dishes' as described by @Anonymous AFAIK they're for fibre cable strain relief.
