RDP Port Forward Help
aksmith04
Browser
Hi, I want to port forward RDP so i can access my PC from work as and when i need to without using teamviewer etc.
Anyone been able to acheive this? When i went into the router settings i could not see in the list of applications RDP under port forwarding?
Any help is appreciated.
1 REPLY 1
npr
Fixes: 8
Re: RDP Port Forward Help
RDP uses tcp port 3389.
You can either create a application for that port and then forward the application you've  created, or just make a rule to forward port 3389 top.
