Question number: 81051624
jasonfreeman
Can someone from the plusnet support team answer my question please?
11 REPLIES 11
Pettitto
Fixes: 5
Re: Question number: 81051624
Your Support Ticket is being worked on by a member of the Support Team as we speak.
You should get an update to this within the next few minutes.
jasonfreeman
thanks chris
jasonfreeman
can a support team member just read my comment i just added please?
Chris
Legend
Fixes: 169
The support guys will pick this up and reply asap Jason.
jasonfreeman
Are anyone able to reply to my support question?
Oldjim
Fixes: 63
When it gets to the front of the queue as Chris implied
jasonfreeman
Are someone from the support team able to answer my support question number: 81051624
Pettitto
Fixes: 5
Your ticket has just been responded to.
jasonfreeman
I have just plugged my router into the test socket and would like to ask if i could have my line monitored for faults or disconnections in the next 48 hours if that is possible?
jasonfreeman
are you able to monitor my line for the next 48 hours and are you able to post a graph of my connection over the past week please?
Oldjim
Fixes: 63
Why don't you let the faults team get on with their job and exhibit a little patience.
You are not the only customer with problems so continually posting here requesting immediate action won't help in the slightest unless your ticket is being ignore which yours certainly hasn't been
