Question about Openreach ONT
Stillgame2026
Hi all Smiley
So I recently had Openreach on behalf of Plusnet install new FTTP line/box to house, no issues. Talking to the guy next door today and he also had a new line installed by Openreach and the same contractor as me but he is with Sky.
We both have same package 900meg and get about 935 over wired and he gets 980.
So he has the Zyxel ont and i was given the adtran sdx611.
So my question is why two different boxes and whos is newer and better ?
8 REPLIES 8
Fixes: 388
Re: Question about Openreach ONT
@Stillgame2026 Openreach use both types - at least - and all depends what the installer is given for each connection/what they have on the van.
As both you and he are on the 900 package, unless you have massive families, or more 'connected' kit than a hotel, I wouldn't worry.
Fixes: 585
some of that difference could be attributable to the PPPoE overhead
Stillgame2026
One more thing just to clear my mind Smiley
Looking at the pole over the road my cable seams to have a sag in it near to the pole not my house where as all the others seam to look much tighter, could a Sagg in my new line cause any damage to the cable ?
Fixes: 388
Not really - there are four other lines connected to our pole, all of varying 'sagginess' and none of us have any issues - unfortunately I would know, as i seem to be the 'go-to' individual if my neighbours have internet issues.
Stillgame2026
I don`t have any issues I just noticed that from the pole side its now starting to sag a little where as the others about 6 all seam to be much tigher coming from the pole.
Just wondered was it something to keep and eye on or is this fine. thanks for the rely`s @jab1 and @MisterW
PhilipHeyes
Seasoned Champion
Fixes: 26
Do remember your 935Mbps is just about as good as it gets via a 1Gbps Ethernet network connection on the ONT or the Router or the Computer.
980 might just be an illusion if it is a speed test in a web browser.
Fixes: 118
@Stillgame2026
Not directly related to your query but the following was posted today about Zyxel ONT's
https://www.ispreview.co.uk/index.php/2026/04/openreach-install-500000-green-zyxel-onts-via-uk-fttp-...
Stillgame2026
Thanks Brian Smiley
If Openreach are installing these newer Onts does this mean Plusnet can soon offer 2gb connections then ? And those of you who are on fttp with plusnet do you have a 1gb box installed or the 2.5 just out of intrest.
