Question: 81051624
jasonfreeman
Question: 81051624
What does this mean?:
We would like to inform you that your Help Assistant Question [ 81051624 ] has now been returned to the BOT - Phone Faults - Logged Appointments pool. A member of our Support Team will investigate your issue as soon as possible.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Question: 81051624
It means that your Fault Ticket has been released from hold following the engineers visit.
Our Faults Team will now pick your ticket back up and check the engineers notes and run a further couple of tests to ensure the fault has been resolved.
Chris Pettitt
Cloud Environments Engineer
jasonfreeman
Do you know rouphly when my ticket will be viewed and tests completed?
Plusnet Staff
Plusnet Staff
Fixes: 5
Generally within 48-72 hours of the ticket coming back off hold.
Chris Pettitt
jasonfreeman
Ok thank you and are you able to reply to my forum "streaming failing" please?
Plusnet Staff
Plusnet Staff
Fixes: 5
I can't see that the thread really needs a response.
It's now a case of waiting for the Faults Team to get back to you as above.
Chris Pettitt
jasonfreeman
I've just added a comment on it now
