Question #70221075 - Can you update my question please?
shalom2010
I reported a fault on Friday 31st May and requested that I'm updated via text message, however, I'm not using my brother's wi-fi connection, so am able to access the Member Centre. Could this be noted on my
question please (as my mobile phone is not always switched on). Thanks.
1 REPLY 1
chrispurvey
Re: Question #70221075 - Can you update my question please?
I've noted that on there for you. I can see that your sync rate has improved.
Our faults team will be in-touch with their findings.
