QUIET cooler for am3+?
Fixes: 21
So I am happy with my new pc bar the cooler, it sounds like a hoover  Shocked
So anybody got any recommendations for a quiet cooler for an Athlon x8 procy.
I have had a look on ebay and these look interesting:
1
2
3
4
Not sure if 2 would fit, need to check height of it vs case.
VileReynard
All Star
Fixes: 11
Re: QUIET cooler for am3+?
rongtw
Fixes: 12
Zalman is cooler on your list i would even try .
But if you are worried over space try a AIO water cooler , cant go wrong mine is virtually silent http://www.scan.co.uk/products/corsair-h55-factory-refurbished-hydro-series-cpu-cooler a bit more cash but worth it
Fixes: 67
I've used one of these http://www.aria.co.uk/Products/Components/Fans+%26+Cooling/Air/Arctic+Cooling+Freezer+7+PRO+Rev.2+Qu... in the past on an AM3 based system and it was pretty quiet ( and not too expensive! )
Fixes: 21
Cheers guys will look at the options
nanotm
the problem with those tower fan type units is the fan itself, personally I have a hyper evo212 cooling tower, on 1 pc it runs quite as a mouse on the other it makes a horrendous noise, only difference between them being the fans in use, finding "quiet" fans seems to be a complete nightmare
so next time I have an need to replace mine i'll be going water cooled
One thing I've noticed is nobody has asked this question I had to ask a customer in the computer shop asking about heatsinks; What are you using the computer for?
If it's just every day browsing, I'd suggest Zalman cooler no. 4 in the list there, if it's youtube video editing or average gaming, Zalman cooler no. 2, and for heavy performance gaming, Zalman no. 1...
I'd also suggest fitting a 120mm low-RPM case fan in the back of system, if it has the space for one, on all levels of cooling, get the heat sucked out the rear to reduce the heat built up inside that usually ends up going through the PSU causing excessive dust buildup and overheating inside the PSU case, the more air that is moved, the less the CPU fan needs to run at top speed... Smiley
Just another thought, if you haven't already done so, in the BIOS look for AMD Cool 'n' Quiet and turn it on, that way the CPU fan will slow down at low loads and  only speed up at higher loads... Smiley
Fixes: 21
Cool & Quiet is on. It is during gaming that it sounds worse (under Win7). At the mo, (In Linux & web browsing etc) it is quiet as a mouse.
e.g. when playing Borderlands it is running full out.
I have ordered "Arctic Cooling Freezer 7 PRO Rev.2 Quiet CPU Cooler " got a 2nd hand one on ebay.
The case hasn't got room for a 120mm one but I have an 80mm one on order. With the holls it will be middle of next week before I get them.
Fixes: 21
Added the 80mm fan to the case. WHAT a difference. No more full out fan, cpu's are running @<35C running Borderlands.
The cpu fan maybe overkill now, but I have ordered it.
Better to have all the cooling you can get when gaming, CPUs perform better the cooler they are... Smiley
VileReynard
All Star
Fixes: 11
Use liquid Helium.
CERN do.
Only problem there is his computer will float away... Grin
Fixes: 188
Or he'll start speaking in a squeaky voice.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 21
Quote from: MisterW
Does anyone have the AMD clips spare for this cooler? (or know where I could get them?)
The seller I got it off only had the Intel clip and couldn't find the AMD ones.
