Processor Affinity
- Processor Affinity
Processor Affinity
01-05-2015 5:37 PM
Forum Moderator and Customer
Re: Processor Affinity
01-05-2015 6:12 PM
01-05-2015 6:19 PM
Overnight I set Handbrake to use all 6 cores at the highest priority and things zip through quite nicely.
06-05-2015 8:03 PM
07-05-2015 11:06 PM
08-05-2015 12:11 PM
Actually difficult to draw a line and say exactly what you mean by 'Windows' here. If you mean all the system processes such as indexing, disk handling, etc etc etc I think it quite likely it would often use as many cores as you have.
08-05-2015 1:27 PM
08-05-2015 1:29 PM
I'd expect it to be smoking where it boots so fast but its just as slow as the old machine. I appreciate that hard drives still work at the same speed but with 8 cores, there should still be a noticeable difference - especially when a single core machine doesn't have the HDD constantly turned on during boot.
AFAIK windows runs on one core but then does a round robin (or similar) with all other processes on all the available cores?
Looks like matthews has beat me to it with a similar suggestion..
08-05-2015 2:40 PM
I've only get 4 cores, so it's never been worth the bother of limiting the number of cores.
Handbrake just runs each core at 99+%
08-05-2015 2:53 PM
I'm surprised 8 cores didn't improve boot time a bit, but usually boot is pretty much I/O bound so it wouldn't make all that much difference. If you have network connections around, especially ones that are not actually available, that can slow boot down while Windows waits to try to connect. It can also really slow down bringing up a file dialog box, even when it shouldn't need to go near the missing resource.
08-05-2015 3:36 PM
I've noticed on my C2750 (8 core atom) that when it's not doing a lot cores 5-8 have no utilisation at all, but as soon as things start getting busy they start showing load.
08-05-2015 8:56 PM
08-05-2015 11:51 PM
Quote from: dragon2611 I'm pretty sure that when cpu load is very low most modern OS's can actually put cores to sleep to save power.
Well I'm on Win7 pro and i've not found anything that indicates it can sleep a core. If the computer isn't doing much then the cores will of course show 0% useage - thats normal but doesn't mean they've been put to sleep. If you sit and watch them for long enough you will every now and then see a core go to 1% before going silent again.
This is my current task manager:
I don't have a great deal running at the moment but i've been putting windows to sleep every night and then waking it up the next day for over a month - which in its own right tends to confuse windows and cause it to start using more resources. I have my browser using over 1GB of ram, google earth open, firefox and a few other programs however if i did a clean reboot most of those cores would be at 0% (sorry i won't be proving that lol - too much hassle).
Quote from: sjptd I'm surprised 8 cores didn't improve boot time a bit, but usually boot is pretty much I/O bound so it wouldn't make all that much difference.
I was surprised too and a bit miffed by it to be honest but i suppose it's just one of those things. The main core of windows is never going to be multiple threads, it will be one that controls everything else and spawns new threads for new processes etc so when you think about it logically, it couldn't really one on more than one core when booting up anyway. Well.. thats my take on it lol.
09-05-2015 9:38 AM
If there is one controller thread it would be arranged to do almost no work itself, and so should not be a bottleneck under usual circumstances (including boot time). Despite what you said earlier about HDD appearing to be inactive during part of boot, system SSD is generally accepted as the best way to improve boot time (Windows or Unix).
09-05-2015 9:41 AM
There are times that when using affinity will give you a noticeable increase in performance, but this is subject to the amount of data being used by the affinity bound threads, the load on the machine, the size of the various caches (L1, 2 and 3 if you have one), and the amount of the data being used by the other threads.
