Processes running in Window Task Manager
Rourkefamily
I am surprised the number of processes I have running when I open Windows task manager. With no program windows open I have 44 processes running. Is this right?
OK. Most are not using any memory space, but it still seems like a high number to me.
10 REPLIES 10
pierre_pierre
Re: Processes running in Window Task Manager
welcome back
thats Windows for you and why a lot of people dont like it
HPsauce
Not really, that's Operating Systems for you.
It's the way most work; processes ready to deal with "events" running at the appropriate priority.
Much better than a huge monolithic lump of code.
Steve
Seasoned Pro
RourkeFamily to answer your question 44 does sound about right, Nothing to worry about.
If life gives you lemons, make lemonade.
pierre_pierre
was going to look at on my Win 7, stupid interface, cant find it  (home premiun)
Cliff_Jordan
Right-click taskbar ...and there it is?  I've got 85 running on my W7, but it is a Vaio laptop Roll_eyes
pierre_pierre
Ah So    Tongue six programs running and 84 processes
Steve
Seasoned Pro
Rourkefamily asked the question when NO programmes are running, Except probably antivirus.
pierre_pierre
switched off most programs and still 69 processes
Steve
Seasoned Pro
44 processes running here and that's with one window open, Only prog auto-updating Is my AV.
HPsauce
My desktop W7x64 system (that I'm writing this on) currently has 58 processes running, as identified by Process Explorer (somewhat more informative than Task Manager).
Other versions of Windows will vary.
And some of the mainframes I've worked on would have several orders of magnitude more than that.
