Problems with external drive
- Problems with external drive
- « Previous
- 1
- 2
- Next »
Re: Problems with external drive
02-01-2011 7:42 PM
this what I call cheap http://www.amazon.co.uk/Hard-Drive-Caddy-Cost-Black/dp/B000I2JU6A
02-01-2011 7:43 PM
I have the pc on the floor and the external disk on top of the pc thats why it was only 2 feet should have had the external hd on the floor as well but hindsight is a wonderful thing if we had it....
02-01-2011 8:34 PM
Sorry i am not sure how putting it in a caddy will make it work ?
02-01-2011 8:39 PM
I didnt say it would, but that will tell you if it is the Porche bit or the disk
02-01-2011 9:10 PM
An external hard drive is a standard hard disc inside a caddy. Now you could take the drive out of the Lacie caddy and put it in a different caddy but surely the better option is to eliminate USB & caddies and temporarily connect the failing hard drive directly to the motherboard?
16-01-2011 9:12 PM
I can confirm that the freezer method can work.
The advice given to me was to put it in the freezer for between 1 and 3 hours. I had a disc (80GB) that failed with clicking and squealing and after freezing for around 2 hours I was able to get some of the data off before it failed again. IIRC I did this twice more before it gave up completely and nothing would help. By then I'd recovered over half the data.
Forum Moderator and Customer
- « Previous
- 1
- 2
- Next »
