Problems with Google Chrome
- Problems with Google Chrome
18-06-2017 8:42 PM
Some members may recall a while ago I was having trouble with getting Chrome to start. I was offered a number of solutions, sadly none of which worked and I just put up as I don't need it very often with needing a number of attempts to get Chrome to open which it usually did, 10 attempts was my record, using Task Manager to "end task" each time..
Today, I was tinkering with removing the Win 10 shortcut overlay (successfully as it happens) one result of this is that Chrome now opens every time without any problem.
Uhmm!! I wonder why?
Re: Problems with Google Chrome
19-06-2017 8:38 AM
@petlew wrote:
... the Win 10 shortcut overlay....
The what? Do you mean you removed a shortcut to Google Chrome or that you somehow removed the shortcut function from Windows?
19-06-2017 8:43 AM
@ReedRichards I'm thinking @petlew might be referring to the curled arrow icon that appears on desktop short cuts to show that it's a link to an application and not the application itself.
19-06-2017 10:32 AM
19-06-2017 11:09 AM
Quite right mook, that is exactly what I meant (Its what Microsoft call it).
Its a Registry tweak. The one I used offers no arrow, smaller arrow or larger arrow. I had no arrow.
And chenks76, you're right too, I spoke too soon. After 10 or more test consecutive (some split by restarts) openings of Chrome yesterday without a problem, My first use this morning finds me back where I was needing the Task Manager to get it going again. Starting the third try.
19-06-2017 11:20 AM
@petlew, you might want to have a look at the network traffic while this jam is in place, it may provide some insight as to why chrome is stalling like it does.
19-06-2017 11:23 AM
20-06-2017 8:09 AM
Yes, Chrome maintains a User Data folder that is not deleted if you uninstall and re-install Chrome. In my experience it's the most likely source of persistent problems. In my case it is located in App data > Local > Google > Chrome . Back-up anything you want to keep first then delete or rename the folder.
