Problems updating (SOLVED)
Fixes: 9
Not sure why I get these messages when updating as some packages are clearly updating but not these ones,
Failed to fetch http://packages.linuxmint.com/dists/maya/main/binary-i386/Packages  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/upstream/binary-i386/Packages  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/import/binary-i386/Packages  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/import/i18n/Translation-en_GB  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/import/i18n/Translation-en  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/main/i18n/Translation-en_GB  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/main/i18n/Translation-en  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/upstream/i18n/Translation-en_GB  Unable to connect to packages.linuxmint.com:http:
Failed to fetch http://packages.linuxmint.com/dists/maya/upstream/i18n/Translation-en  Unable to connect to packages.linuxmint.com:http:
Some index files failed to download. They have been ignored, or old ones used instead.
Linux mint 13 64 bit
1 REPLY
Fixes: 9
Re: Problems updating
Problem solved.
If anyone else has this problem go to the following link,
http://forums.linuxmint.com/viewtopic.php?f=90&t=122213
