Problems accessing ancestry.co.uk
- Problems accessing ancestry.co.uk
18-08-2015 6:26 PM
I have tried a number of things, including mint/opensuse13.2, different browsers, a new (clean) user, even going via a UK or US proxy, but the only change that seems to work is altering the MTU. Reducing the router value to 1476 or reducing the OS value to 576 (opensuse has preset values of 576, 1492 and 1500) gets it working fine and probably the fastest it has ever worked
Ancestry is the only site I use that I have found to be a problem and, using tracepath, the route from Plusnet goes via prolexic.com (a company providing security and DDoS protection equipment/routing, I believe) which sometimes returns a path mtu 1476 in the tracepath response for a MTU of 1492. The first tracepath entry after the plusnet entries is unknown.prolexic.com for 576 and blackhole.prolexic.com (DDoS protection?) for 1492.
I have a static 212.159.x.x ip address.
Any suggestions on finding where the problem lies?
Anyone using linux to access ancestry?
Phil
Re: Problems accessing ancestry.co.uk
19-08-2015 9:54 AM
I do use an advert blocker, though.
19-08-2015 10:04 AM
19-08-2015 1:48 PM
a) using my router (TP-Link TD1043ND v1) there are problems as described
b) using my mobile as a hot-spot (ignoring the PAYG T&Cs
c) connecting directly using PPPoE instead of the router the site works fine
d) restoring saved router settings from before the problems started has no noticeable effect
So, it would appear that the router is the culprit - whether configuration or "generic".
Phil
19-08-2015 1:56 PM
P.S. I too have a static addresses.
19-08-2015 2:02 PM
Static IP
Non-plusnet router.
non-plusnet DNS.
adw@nofate:~$ tcptraceroute.mt www.ancestry.co.uk 443
Selected device eth0, address 10.0.1.20, port 50433 for outgoing packets
Tracing the path to www.ancestry.co.uk (66.43.22.170) on TCP port 443 (https), 30 hops max
1 10.0.1.254 0.347 ms 0.296 ms 0.291 ms
2 lo0.11.central11.ptw-bng01.plus.net (195.166.128.171) 14.273 ms 14.479 ms 14.210 ms
3 irb.11.PTW-CR02.plus.net (84.93.249.18) 47.669 ms 14.399 ms 14.609 ms
4 ae2.ptw-cr01.plus.net (195.166.129.4) 14.645 ms 48.017 ms 14.670 ms
5 blackhole.prolexic.com (195.66.224.31) 16.323 ms 16.199 ms 16.305 ms
6 unknown.prolexic.com (72.52.60.200) 15.277 ms 15.416 ms 15.862 ms
7 unknown.prolexic.com (72.52.60.205) 32.639 ms 21.922 ms 18.913 ms
8 * * *
9 unknown.prolexic.com (209.200.160.136) 146.347 ms 146.522 ms 146.649 ms
10 66.43.22.170 [open] 151.643 ms 152.044 ms 151.650 ms
A router could victimise a website by caching an out of date DNS entry longer than it's supposed to.
19-08-2015 2:49 PM
To be is to do - Kant
do be do be do - Sinatra
19-08-2015 3:31 PM
19-08-2015 9:15 PM
Quote from: Mook That's sound all wrong to me, I'm not implying anything by it but how can a router 'victimise' a website?
I don't understand the mechanism but, from what I've read, it is possible for a variation in packet sizes to "confuse" a badly implemented interface. Whether it is the Ancestry configuration or my router is subject to debate, though not using my router removes the problem.
Quote from: avatastic A router could victimise a website by caching an out of date DNS entry longer than it's supposed to.
Haven't used the router for DNS from well before it was found vulnerable to hacking - it is provided by a Mint based system using OpenDNS with "moderate" filtering (though I used no filtering during testing). There is no difference using Plusnet DNS.
Phil
20-08-2015 1:08 AM
Although it fails with Firefox, it "works" with wget
Quote wget www.ancestry.co.uk
--2015-08-20 00:58:31-- http://www.ancestry.co.uk/
Resolving www.ancestry.co.uk (www.ancestry.co.uk)... 66.43.22.170
Connecting to www.ancestry.co.uk (www.ancestry.co.uk)|66.43.22.170|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 25407 (25K) [text/html]
Saving to: ‘index.html’
index.html 100%[============================================================>] 24.81K --.-KB/s in 0.006s
2015-08-20 00:58:31 (4.05 MB/s) - ‘index.html’ saved [25407/25407]
20-08-2015 9:43 AM
Quote from: vilefoxdemonofdoom I think this is a Windows only website???
Essentially, yes - they only claim to support "windows PCs and MACs", though they also use "windows" for "Microsoft windows"
I have no problems accessing "www.ancestry.co.uk", it loads fast. It is when I send my account details to login that I get no response from "secure.ancestry.co.uk".
I have had a response from Ancestry "help", attributing the blame to the browser though I didn't have the latest test results when I contacted them.
This AM I applied a factory reset to the router which, as expected, made no difference.
Something that may be significant (or not!) is that I have now found another site with, possibly the same, problems. My energy supplier likes to have customer readings monthly (they also encourage that by donating a small amount to charity for every reading) but, since they updated their website, it has become slow and whilst it accepts the reading it does not return an acknowledgement, just hangs. So that's two very new websites upgrades with problems. It's beginning to look like a backwards compatibility problem
Phil
20-08-2015 10:53 AM
Do you have some ad-blocking or on-line security helper?
I have found that some sites will not load pages with forms due to these. e.g. ofcom.org, Plusnet's chat window.
Try Firefox in safe mode (this can be found on the menu) and see if the issue goes away. If so, the you will need to add the site as an exception to the ad-block or security add-on.
20-08-2015 5:24 PM
It appears there is an incompatibility betwixt my router and Ancestry.
I have spent much of today trying different things and found that by replacing the stock firmware with DD-WRT firmware the problem disappeared and just about everything loaded faster
I don't currently have a spare, so will now have to decide whether a router or a VDSL combo (saving a massive £15 per year) will be better - I've been following the various "what should I get" threads
Phil
26-08-2015 2:35 PM
As I have signed up to Plusnet TV and didn't have 2704n (I declined when changing to fibre) I was automatically sent one
Just plugged it in then changed the WR1043ND to use dynamic IP on the wan interface and plugged that into the 2704n. Not ideal, but it does allow me to use 11n300 wireless
Result - Ancestry now works through the WR1043ND
Phil
