Problems With IE8(SOLVED)
- Re: Problems With IE8
18-02-2010 4:06 PM
18-02-2010 4:09 PM
https://developer.mozilla.org/en/controlling_dns_prefetching
18-02-2010 4:22 PM
18-02-2010 4:32 PM
What are the DNS settings in Windows
You can get them by running ipconfig /all from the DOS window (note the space between ipcofig and /all
18-02-2010 4:48 PM
18-02-2010 4:50 PM
18-02-2010 4:53 PM
18-02-2010 5:01 PM
18-02-2010 5:51 PM
You are using your router as a DNS server. This may be part of the problem
The reason the DNS server is showing up as your router as you have the router set to get DNS servers automatically. If you change them to defined servers then that reflects straight through to windows.
Alternatively you can change the DNS servers in Windows 7 as follows
Go to Control Panel
View Network Status and Tasks
Click on Local Area Connection
Properties
Internet Protocol v4
Properties
I use 8.8.8.8 as Primary (Google) and 212.159.3.50 as Secondary (Plusnet) but I have them coded in my router and it shows up in ipconfig as follows
DNS Servers . . . . . . . . . . . : 8.8.8.8
212.159.13.50
Note to copy and paste from a DOS window right click in the window and select either Mark (then you can select the bits you want in the text) and then press the enter key. You can then paste it into the post. Alternatively you can click on Select All then press return to copy the lot.
18-02-2010 6:26 PM
Heres the full dos now..
Edit ok ive managed it the first way you described there oldjim and heres the dns from dos..
212.159.13.50
Is it fine to leave them settings in my router also?
18-02-2010 7:26 PM
18-02-2010 7:31 PM
A quick Google found how to disable it as it isn't necessary
Teredo is enabled by default on Windows Vista/7 but is inactive until required.
http://www.sevenforums.com/network-sharing/46575-teredo-tunneling-issue.html
18-02-2010 9:25 PM
I tell you,new pc,new windows,its just been a right burger this last while,allsorts playing up and causing havoc,im not changing again ever
Many thank's for your help,it's been very much appreciated,thanks to everyone else though here who chipped in there pennies worth.(just one of the reasons i like this forum,full of great knowledgeable folk's)
