Problem with Audigy 2 sound card
Fixes: 62
My Audigy 2 sound card seems to work fine except when I try to record what you hear.
I have tried with the Creative software and also with Audacity and I get the same problem. The resulting sound is massively distorted. Record volumes seem OK and it used to work in my XP machine but I am now using Vista 64 bit.
Before I put the card back into the XP machine to test are there any suggestions as to the cause/solution.
techguy
Re: Problem with Audigy 2 sound card
Hi Jim
Are you using the latest driver dated 17th July 08 from creative.com? http://tinyurl.com/5joqgg
Fixes: 62
I was - however I reinstalled them (1 BSOD and two reboots later) it now works properly
Thanks for reminding me about reinstalling drivers  Embarrassed
techguy
No problem.
Thankfully, some tech problems are still as simple to solve as that.
Smiley
StickyMick
Thanks for that link Techguy.
See if it solves my Audigy4 problem. Wink
