Problem with Audigy 2 sound card
- Re: Problem with Audigy 2 sound card
26-01-2009 6:28 PM
My Audigy 2 sound card seems to work fine except when I try to record what you hear.
I have tried with the Creative software and also with Audacity and I get the same problem. The resulting sound is massively distorted. Record volumes seem OK and it used to work in my XP machine but I am now using Vista 64 bit.
Before I put the card back into the XP machine to test are there any suggestions as to the cause/solution.
4 REPLIES 4
26-01-2009 8:07 PM
Hi Jim
Are you using the latest driver dated 17th July 08 from creative.com? http://tinyurl.com/5joqgg
26-01-2009 10:42 PM
I was - however I reinstalled them (1 BSOD and two reboots later) it now works properly
Thanks for reminding me about reinstalling drivers
27-01-2009 5:39 PM
No problem.
Thankfully, some tech problems are still as simple to solve as that.
31-01-2009 11:56 AM
Thanks for that link Techguy.
See if it solves my Audigy4 problem.
