Problem using Devolo plugs on 5Ghz
david283
Thanks for any advice on this one..  I am trying to get my smart TV to connect to my Devolo network extension plug on 5Ghz but the plug is only offering me 2.4Ghz wifi.  I have even turned off my 2.4Ghz on my router and only left on my 5Ghz wifi and re-synched the plugs but they seem immune to being forced to synch and adopt 5Ghz and remain on 2.4Ghz.  Any help?  Thanks,
2 REPLIES 2
VileReynard
Fixes: 20
Re: Problem using Devolo plugs on 5Ghz
Maybe the plugs are 2.4GHz only?
Champnet
Fixes: 21
Model number would be helpful.
Some units will not use the 5GHz band and others will not use both bands together. If you have one of these and a mobile is connecting at 2.4Ghz nothing is going to connect at 5Ghz.
