Problem sending email with attachment
- Problem sending email with attachment
10-05-2014 12:55 PM
Webmail tells me that it's greater than the 7MB limit - can that be changed?
Outlook 2010 informed me it was greater than the 20MB limit initially set and found a fix for that.
But when I send click Send the email goes straight to the Sent folder with the green progress bar appearing at the bottom only briefly. With an upload speed of only 1MB I would expect it to take over a minute to send.
I've never had such a problem with Outlook 2007 which is on the main PC but I only have the laptop at the moment so am a bit stuck.
Can anyone offer further advice, please.
Forum Moderator and Customer
Re: Problem sending email with attachment
10-05-2014 1:55 PM
For a file that size using Dropbox might be more appropriate.
M
10-05-2014 2:02 PM
I have been able to send files larger than that to some receipients using Outlook 2007 from my main PC at home.
10-05-2014 2:07 PM
10-05-2014 2:25 PM
I will reduce the size of the jpegs then see what size pdf file they make. If still too large then will probably just send the jpges in a zip/rar file.
10-05-2014 2:31 PM
In which case you could change the resolution of the pdf images when you convert them - this may be more useful
10-05-2014 2:39 PM
10-05-2014 3:25 PM
This is how to do it http://www.tracker-software.com/knowledgebase/289-How-do-I-make-my-PDF-documents-smaller-file-sizes
10-05-2014 3:33 PM
I then used the batch conversion to reduce the dpi from 300 to 100 then converted to pdf with the resultant file being a more manageable 11MB.
That file was sent ok but was returned as undeliverable to the email address given so I reckon they have some miniscule limit as a text only email has been received without issue.
10-05-2014 5:50 PM
10-05-2014 6:05 PM
Then email a link to your file.
10-05-2014 8:39 PM
10-05-2014 8:41 PM
10-05-2014 9:24 PM
Quote Choosing Condoleezza Rice for Dropbox's Board is problematic on a number of deeper levels, and invites serious concerns about Drew Houston and the senior leadership at Dropbox's commitment to freedom, openness, and ethics. When a company quite literally has access to all of your data, ethics become more than a fun thought experiment.
