Problem sending email with attachment
Mav
Fixes: 515
The attachment is a 66MB pdf file.
Webmail tells me that it's greater than the 7MB limit - can that be changed?
Outlook 2010 informed me it was greater than the 20MB limit initially set and found a fix for that.
But when I send click Send the email goes straight to the Sent folder with the green progress bar appearing at the bottom only briefly. With an upload speed of only 1MB I would expect it to take over a minute to send.
I've never had such a problem with Outlook 2007 which is on the main PC but I only have the laptop at the moment so am a bit stuck.
Can anyone offer further advice, please.
Forum Moderator and Customer
13 REPLIES 13
MauriceC
Resting Legend
Fixes: 17
Re: Problem sending email with attachment
Most Mail systems have an upper limit on File attachment size and 66 Meg is very likely to fail somewhere on route.
For a file that size using Dropbox might be more appropriate.
M
Mav
Fixes: 515
It's a document to Southern Electric so I may contact them on Monday to see if they will be prepared to download from something like DropBox.
I have been able to send files larger than that to some receipients using Outlook 2007 from my main PC at home.
Oldjim
Resting Legend
Fixes: 63
Does the document need to be that big - are there graphics where you could reduce the resolution
Mav
Fixes: 515
Possibly, Oldjim. It's an 11 page scanned copy of the Power of Attorny in relation to my mother. I converted each 2.5MB page to pdf then joined them to form one document.
I will reduce the size of the jpegs then see what size pdf file they make. If still too large then will probably just send the jpges in a zip/rar file.
Oldjim
Resting Legend
Fixes: 63
When you say you converted to a pdf I assume that you scanned as a jpg not as a pdf
In which case you could change the resolution of the pdf images when you convert them - this may be more useful
Mav
Fixes: 515
I used pdf Xchange Editor and dragged each jpg into a blank window then saved as pdf. Couldn't see any options to change the resolution.
Oldjim
Resting Legend
Fixes: 63
Mav
Fixes: 515
I tried batch conversion using IrfanView from jpg to pdf but it failed to save for some reason.
I then used the batch conversion to reduce the dpi from 300 to 100 then converted to pdf with the resultant file being a more manageable 11MB.
That file was sent ok but was returned as undeliverable to the email address given so I reckon they have some miniscule limit as a text only email has been received without issue.
jelv
Fixes: 10
Don't forget that a file is considerably bigger when attached to an email because of the MIME encoding.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
VileReynard
Fixes: 20
Place the file on a web site or on free Cloud Storage such as SpiderOak [not Dropbox].
Then email a link to your file.
shutter
Fixes: 65
How about sending ( say) 5 emails with just a few pages each to make up the total content?
Mav
Fixes: 515
Plenty of options, thanks folks  Kiss
VileReynard
Fixes: 20
http://www.drop-dropbox.com/
Choosing Condoleezza Rice for Dropbox's Board is problematic on a number of deeper levels, and invites serious concerns about Drew Houston and the senior leadership at Dropbox's commitment to freedom, openness, and ethics. When a company quite literally has access to all of your data, ethics become more than a fun thought experiment.
