Problem (of my making!) reinstalling IE9
- Problem (of my making!) reinstalling IE9
28-10-2013 9:42 AM
Please can anyone help? I uninstalled IE9 earlier this morning - and then wanted to reinstall it. Clicked on “Install” and shortly afterwards my line “dropped” (red light came on) - as the IE9 indicated it was “downloading” - I stupidly stopped that installation.
Now that my connection is running OK, I’ve tried to continue the process but, soon after clicking “Run” another message appears onscreen: “Another installation is currently in process. Finish that installation or removal and try setup again.”
This suggests that because IE9 was already installing - and because I stopped it, it now wants me to continue from the point I cancelled. Obviously, I cannot continue from that point, nor can I reinstall it from the beginning! Can anyone offer any advice on how I might progress on this?
PS Re: my B/B connection “dropping” - this is due to my line being “in training” - as arranged by Technical Support.
3 REPLIES 3
Re: Problem (of my making!) reinstalling IE9
28-10-2013 10:20 AM
Try.... reboot the computer.... it may "clear" the existing version, and then you can start again....
28-10-2013 10:24 AM
Or do a restore to a point before the install.
Customer and Forum Moderator. Windows 10 Firefox 85.0.2 (64-bit)
28-10-2013 7:21 PM
Thanks for the replies - did a System Restore and . . . . it works! Now why didn't I think of that?
