Problem connecting to sites
I am finding it impossible to connect to http://www.plus.net/ at present.  Other sites are loading slower than normal.  Is there a problem?
pierre_pierre
Re: Problem connecting to sites
Sundog
Is this effecting for any reason my CCGi FTP settings?
all of a sudden I cannot access any of my folders? keep getting a 403 Forbidden issue even though i have R,W,E all set to 777?
hmm.. any ideas./
pierre_pierre
yes try reading the above link
All seems back to normal again.  Apparently CS wasn't aware of the problem initially Sad
Sundog
nope.. CCGI. still down for me.
Still 403 Forbidden on all folder.. will try resetting the persmissions to them.. but I doubt this is going to make a difference..
can log into the ftp fine.. but cannot access the images over a browser in a sub folder
Yep.. as I thought.. just reset persmissions and still 403 on all my folders..
whats going on Plus Net.. c'mon
Sundog
Hi guys.. i'm still having an issue connecting to my sub folders with a message that states..
"Forbidden
You don't have permission to access /ebaypics/ on this server."
i;ve never had this before? whats going on?
cheers
ramidoodle
just tried to ftp to your cgi space. I can get into all folders without any problems
Can you please try it again using windows explorer with your username/password by going to:
ftp://ccgi.plus.net/
keep us posted Smiley
Sundog
Sad hmm..
i've always been able to access my folders when needing to host a file by using a direct http route like this "http://ccgi.sundog1.plus.com/ebaypics/"
what has changed for me not to be able to see the folder index? - i've been able to do
Ooops sorry - haha.. my mistake.. was thinking of the standard FTP haha.. sorry all ok now  Roll eyes Tongue
