Problem connecting to sites
- Problem connecting to sites
04-01-2009 7:12 PM
I am finding it impossible to connect to http://www.plus.net/ at present. Other sites are loading slower than normal. Is there a problem?
8 REPLIES 8
Re: Problem connecting to sites
04-01-2009 8:20 PM
see http://community.plus.net/forum/index.php/topic,72529.msg573322/topicseen.html#new
been off and on all afternoon
04-01-2009 8:27 PM
Is this effecting for any reason my CCGi FTP settings?
all of a sudden I cannot access any of my folders? keep getting a 403 Forbidden issue even though i have R,W,E all set to 777?
hmm.. any ideas./
hmm.. any ideas./
04-01-2009 8:36 PM
yes try reading the above link
04-01-2009 8:47 PM
All seems back to normal again. Apparently CS wasn't aware of the problem initially
04-01-2009 11:18 PM
nope.. CCGI. still down for me.
Still 403 Forbidden on all folder.. will try resetting the persmissions to them.. but I doubt this is going to make a difference..
can log into the ftp fine.. but cannot access the images over a browser in a sub folder
Yep.. as I thought.. just reset persmissions and still 403 on all my folders..
whats going on Plus Net.. c'mon
06-01-2009 7:20 PM
Hi guys.. i'm still having an issue connecting to my sub folders with a message that states..
"Forbidden
You don't have permission to access /ebaypics/ on this server."
i;ve never had this before? whats going on?
cheers
"Forbidden
cheers
06-01-2009 8:07 PM
just tried to ftp to your cgi space. I can get into all folders without any problems
Can you please try it again using windows explorer with your username/password by going to:
ftp://ccgi.plus.net/
keep us posted
keep us posted
07-01-2009 10:25 PM
hmm..
i've always been able to access my folders when needing to host a file by using a direct http route like this "http://ccgi.sundog1.plus.com/ebaypics/"
what has changed for me not to be able to see the folder index? - i've been able to do
Ooops sorry - haha.. my mistake.. was thinking of the standard FTP haha.. sorry all ok now
