Problem accessing internet wirelessly
- Problem accessing internet wirelessly
20-08-2009 12:38 PM
My setup is:
Dell Inspiron 6400 with Dell wireless 1390 WLAN minicard
Windows Vista Premium
Thomson v585v7 router
I can access through the ethernet cable everytime.
When I first setup a couple of weeks ago I had sporadic wireless access
but since the 15th August I haven't been able to access wirelessly at all.
The wireless green light is on and I am always connected to the plusnet wireless network connection however when I open internet explorer I am getting the following message:
"Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
What you can try:
Diagnose Connection Problems
More information
This problem can be caused by a variety of issues, including:
Internet connectivity has been lost.
The website is temporarily unavailable.
The Domain Name Server (DNS) is not reachable.
The Domain Name Server (DNS) does not have a listing for the website's domain.
If this is an HTTPS (secure) address, click Tools, click Internet Options, click Advanced, and check to be sure the SSL and TLS protocols are enabled under the security section.
For offline users
You can still view subscribed feeds and some recently viewed webpages.
To view subscribed feeds
Click the Favorites Center button , click Feeds, and then click the feed you want to view.
To view recently visited webpages (might not work on all pages)
Click Tools , and then click Work Offline.
Click the Favorites Center button , click History, and then click the page you want to view."
I have tried to diagnose the connection problems using the explorer prompt without any success.
I have turned off all the electrical equipment in the house to check that there is no interference and I have also tried all 13 of the wireless channel settings on the thomson 585v7 router however none of these has helped.
I have also disabled my firewall, again no joy.
I'm not sure if it is relevant but having looked at other posts on this forum, I have noticed that sometimes problems are caused by DNS servers so just in case here is my 'ipconfiga/all':
C:\Users\Jaimie.Home-PC>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Home-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Dell Wireless 1390 WLAN Mini-Card
Physical Address. . . . . . . . . : 00-1D-D9-3E-87-B0
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::9d9c:63c2:6fdc:791e%10(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.121.30(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 167779801
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controlle
r
Physical Address. . . . . . . . . : 00-1C-23-B1-BB-58
Link-local IPv6 Address . . . . . : fe80::61d4:4324:43f2:eb00%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.64(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 19 August 2009 20:59:30
Lease Expires . . . . . . . . . . : 20 August 2009 21:08:21
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 201333795
DNS Servers . . . . . . . . . . . : 192.168.1.254
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.lan
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.64%14(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Link-local IPv6 Address . . . . . : fe80::5efe:169.254.121.30%24(Preferred)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : isatap.{5DACB543-CE62-4B95-BBBE-F96F42BF5
09B}
Tunnel adapter Local Area Connection* 11:
09B}
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : 6TO4 Adapter
I am a beginner when it comes to computers + broadband so please assume no prior knowledge if you have any suggestions to resolve this.
I hope someone can help.
Thank you.
Re: Problem accessing internet wirelessly
20-08-2009 1:09 PM
tracert www.google.com
then press enter and see what happens.
20-08-2009 4:46 PM
20-08-2009 6:52 PM
Check that you are using the same security options on both ends, and that you have set the same key at both ends.
If that is a struggle, then turn off the wireless security (temporarily) altogether, and see if you can connect. If you can, turn it back on and make sure you use the same options (although if I remember correctly Vista selects the options for you).
Another thing you could try is to change the SSID on the router. If yours is still set to the routers default, it is entirely possible that there is another neighbouring network with the same name - that will confuse Vista no end!!!
20-08-2009 7:05 PM
20-08-2009 8:20 PM
Here is the ipconfig/all at the moment:
IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred)
Lease Obtained. . . . . . . . . . : 20 August 2009 19:50:11
Lease Expires . . . . . . . . . . : 21 August 2009 19:50:11
r
The ipconfig/all doesn't mean much to me but I notice that my wireless DNS server now has my routers address and not the plusnet DNS server addresses (212.159.13.49 or 212.159.13.50) I thought it might have?
Can anyone explain what has happened? Is it OK to leave like this or should I change the wireless DNS servers to the plusnet ones as recommended on other posts I have read?
Any advice would be much appreciated.
Thanks for the comments so far.
20-08-2009 8:37 PM
Quote Can anyone explain what has happened?
Yes , you've now authenticated successfully with your router and have got a correct IP address.
The significant bit is here
Quote Wireless LAN adapter Wireless Network Connection:
Whereas, as Wisty explained in the earlier post, you didnt have a valid IP address before i.e not one in the 192.168.1.x range. If the problem persists/reoccurs I would do as he suggests and change the SSID in the wireless settings of your router. Given that you have already tried changing channels it is quite possible that another router in the vicinity with the same SSID could be causing the problem.
Its not a DNS problem so I wouldnt go changing any DNS configuration just yet...
20-08-2009 9:40 PM
My current ipconfig/all is:
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
r
IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred)
Lease Obtained. . . . . . . . . . : 20 August 2009 21:25:39
Lease Expires . . . . . . . . . . : 21 August 2009 21:30:11
This looks the same as in my original post (though I am no expert). Should I try changing the SSID on my router? If so, how do I do this? It is a Thomson 585v7.
Or is there anything else I could try?
Thanks.
20-08-2009 10:08 PM
Without the ethernet cable in this was the response:
C:\Users\Jaimie.Home-PC>tracert www.google.com
Unable to resolve target system name www.google.com.
With the ethernet cable in, this was the response:
Tracing route to www.l.google.com [209.85.229.103]
over a maximum of 30 hops:
1 99 ms 74 ms 99 ms dsldevice.lan [192.168.1.254]
2 29 ms 28 ms 26 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 42 ms 33 ms 30 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 30 ms 34 ms 25 ms 195.66.224.125
5 30 ms 37 ms 27 ms 64.233.175.25
6 40 ms 34 ms 50 ms 72.14.232.134
7 47 ms 40 ms 54 ms 216.239.49.45
8 46 ms 41 ms 59 ms 209.85.243.85
9 42 ms 31 ms 38 ms ww-in-f103.google.com [209.85.229.103]
Trace complete.
Though I can no longer access the internet wirelessly, I can connect to the 'Plusnet Wireless' Wireless Network Connection. It's just when I open up a web browser I am getting the error message described in my original post.
Does this help you diagnose the problem?
Thanks.
20-08-2009 11:47 PM
Look at the icon on the taskbar at the bottom right of the screen that shows two boxes (screens) overlaid. If there is a round symbol (meant to be a globe) towards the bottom right of this icon your computer thinks it has an internet connection. If there is a cross then your computer has lost its connection to the router. If neither the computer is connected to the router but the router is not connected to the internet. Have you been watching this icon to verify the state of your internet connection?
Given that it seems you have an intermittent wireless connection, either the wireless on your router is faulty or the wireless adaptor on your computer is faulty or you are at the limit of the range of the wireless signal (i.e. the computer is too far from the router) or you are experiencing a lot of interference.
21-08-2009 10:03 AM
(My daughter is having similar problems with Sky and one of the things they asked was whether her laptop could see other routers - they were a bit put out by the response which was 17 including 4 Sky routers but they still haven't agreed that the router is faulty )
21-08-2009 10:41 AM
Old Jim, yes I can see other routers, it varies from between 2 and 6. Does this mean my router might be faulty? When I've checked the signal strength of the other routers is one/two green bar out of five. Mine always has the full five green bars. I live in a town centre and their are lots of other house close by.
In earlier posts both wisty and MisterW suggested changing the SSID on my router. Is this still something I should try? If so, how would I do this? It is a thomson 585v7.
Thanks all for you continued suggestions.
21-08-2009 10:50 AM
I don't have a Thompson router running at the moment but when I was using an ST546 which also has wireless I found that the computer intermittently wouldn't connect wirelessly to it when the access settings weren't "Allow new stations automatically".
Can you check to see if that makes a difference
21-08-2009 11:27 AM
21-08-2009 8:50 PM
ReedRichards, with the ethernet cable in I have a globe with the two screens, with no ethernet cable I just have two screens (no red cross). I am only a few metres from my router and have a full strength signal displayed on my wireless netweok connection.
Oldjim, the routers 'Allow new devices' option is set to 'New stations are allowed (automatically)'.
I can currently see 2 other wireless network connections both with a low signal strength (1 green bar out of 5).
Any other suggestions gratefully received...
