Problem Archiving Messages from Outlook .OST file
Fixes: 25
I want to make an archive of some Outlook messages that are stored in a .OST file (collected by IMAP).  When I run the archive routine on Outlook I get quite a large file with no obvious useful content.  If I create a .PST file and try to copy the contents I get a copy of the sent messages but the Inbox contents are not copied.
Am I doing something wrong or trying to do the impossible?  Do I need to use OST to PST conversion software?
18 REPLIES 18
Fixes: 25
Re: Problem Archiving Messages from Outlook .OST file
I debated with myself whether to post this query to Email or Tech Help.  Perhaps a kindly moderator could move this over to Tech Help as it doesn't seem to be getting a response here - and it is essentially a software problem.
Fixes: 43
@ReedRichards - If I read this correctly then I don't think this is what you need, but I could well be wrong of course, and just typing for the sake of it.
Fixes: 25
What I think Microsoft is saying is that emails in a .OST file don't really belong to you, you're just allowed a look-see at files that are stored on somebody's server.  It's the job of the owner of the server to look after back-ups directly from the server; you're not allowed to make your own backup copies.  If this is true then I suppose that is fair enough but I cannot find this stated explicitly so I don't know if it is true or just a misinterpretation on my part.
Fixes: 62
according to this you can't do it unless you use a conversion tool to change them to pst https://www.msoutlook.info/question/802 which you could do by copying the ost file to somewhere else and do it while leaving the original ost file alone
Fixes: 43
I read the article as; if your email is provided by an Exchange Server you’ll have one of these files containing an archive of your email, appointments etc, and with it you’ll be able to view, read an search its content while being offline.
However, in order to make use of this file you must have the support of an Exchange Server to first create it and populate it.
Fixes: 25
@Oldjim, thank you for that helpful reference.
@Mook, the trouble is that if you have a recent copy of Outlook (2013, 2016) then even regular IMAP ends up in an OST file with all the restrictions that imposes on what you can (or can't) do with your messages.  Specifically it seems you cannot keep a local copy without resorting to third-party software.
Fixes: 43
@ReedRichards - OK that seems fair enough, and typically MS, but at least you are wiser now than you were this morning. Smiley
Browni
Aspiring Hero
Fixes: 49
Have you tried dragging the messages from the .ost file to a .pst file?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 25
I tried drag and drop to a PST file on one message and it vanished.  Since the whole point is NOT to lose these messages I gave up at that point. Perhaps I should have tried a bit harder?
Browni
Aspiring Hero
Fixes: 49
Are you copying to the same type of folder, eg, inbox to inbox?
My current inbox which is connected to an IMAP account only contains this months emails, the rest have been moved to an inbox folder in a .pst file which now contains all email from 2006 thru 2016.
Fixes: 25
@Browni are you using Outlook 2013 or 2016?  Is the file to which the mail downloads .OST?
Browni
Aspiring Hero
Fixes: 49
Office 2016 with the mail being delivered to a .ost. The .pst I copy the emails to is only opened when I move emails to it.
Fixes: 25
Thank you @Browni, I'll try again.  if it works I'll award you the fix.
Browni
Aspiring Hero
Fixes: 49
I really hope it works for you as it is such a simple solution.
You actually got me worried a little bit saying that messages were disappearing but I can't recreate that when copying messages from .ost to .pst and vice versa.
I found this in an email from 2004 lol
The estimated download times for Windows XP 64-Bit Edition for 64-Bit Extended Systems (420 MB) are 16 hours 17 minutes @ 56k, 1 hour 28 minutes on DSL, and 37 minutes on T1.
