Printing items from internet probkem
- Re: Printing items from internet probkem
02-10-2008 5:52 PM
http://photo-editing-software-review.toptenreviews.com/ I tried to print from the link but the ticks are not printed what ever I have chosen to do. Why is that and is there a way round that I have missed?
6 REPLIES 6
02-10-2008 5:59 PM
Using Firefox I had no trouble - here is a link to the page as a pdf
Edit - link removed as file is no longer on the server
02-10-2008 6:42 PM
I have FF too, but ir would not allow the ticks printing. What sequence did you use?
Thanks for pdf
Thanks for pdf
02-10-2008 7:01 PM
Just file, Print and I get this in Firefox 3
02-10-2008 7:14 PM
the actual problem Jim, is do a print preview, then set up and make sure the print background button is ticked. If you are going to print it though it will use a lot of ink.
Jim did you know that you can attach a PDF the same as a JPG?
02-10-2008 7:19 PM
Weird as I used Cute PDF. When I opened the resultant file with Adobe ticks were not to be seen, so I did not print from it.
02-10-2008 7:20 PM
Pierre,
You mean this
And no, I didn't even think of checking - will now delete from my website - thanks
You mean this
