Printing From DOS Program on a Mac
- Printing From DOS Program on a Mac
23-09-2007 4:25 PM
Money Manager works fine, under the DosBox Emulator, however I have no way to print from it as DosBox doesn't support printing, without downloading and compiling a patch from CVS which I haven't a clue how to do.
Therefore I either need another emulator which will print directly or a way of taking a CSV (comma separated values) file and turning it into a printable format, then printing it automatically.
If anyone has any ideas on how I could get something like that to work, I would be extremely grateful.
To summarise I am running:
MoneySoft Money Manager v4,
in
DosBox 0.7
on
Apple Mac OSX 10.4 Tiger
Re: Printing From DOS Program on a Mac
23-09-2007 4:49 PM
EDIT: URL to Mac OS X OOo
23-09-2007 5:09 PM
Plusnet Technology
24-09-2007 12:05 AM
Dave that would waste too much ink, unfortunately.
Alternatively how much would it cost to pick up and run a printer that would work on an MS-DOS based system?
24-09-2007 7:06 AM
Quote from: Assos Mike, I'll have a go at that tommorow.
Just a cheap dot matrix? Could probably get a usable one for £5-£15. Don't ask for setup help though, I don't do printing from DOS sorry
24-09-2007 7:19 AM
24-09-2007 7:44 AM
24-09-2007 10:43 AM
24-09-2007 10:53 AM
Prior versions/different windowing systems need to use OOo Aqua I believe, which is in early alpha, so NeoOffice would be the better choice.
24-09-2007 3:28 PM
24-09-2007 4:12 PM
Seriously I'll have a look later once I pick my iBook up from waitrose....
