Printer inks
- Printer inks
Printer inks
23-10-2013 6:56 PM
Re: Printer inks
23-10-2013 7:03 PM
I would get another for my new printer but haven't found any at a reasonable cost.
Re: Printer inks
23-10-2013 7:16 PM
What I will say is printer inks are a con. My partner bought be a nice new hp all-in-one with a doc feeder a while back. 130 pages later and the black is empty. I've done 0 colour printing and they are down to 3/4 too. On the box it claims upto 500 pages
If you want a rock solid cheap to run printer, the old hp deskjets were superior - something like the deskjet 720c. Cartridges lasted forever and were dirt cheap too!
Re: Printer inks
23-10-2013 7:46 PM
When I used to refill my cartridges, I used 100 ml bottles which I think were designed for the continuous ink process, and never had any problems with the print heads on the HP cartridges. Never bought OEM cartridges or ink...
Re: Printer inks
24-10-2013 11:44 AM
If I'm honest, I think the damn things are nothing but a con.
Re: Printer inks
24-10-2013 5:21 PM
The difference between branded inks and other inks is branded inks are calibrated for the YMCB gamtut of the software. In Englishish, they produce almost WYSIWYG. In theory. Also, manufacturer's inks should be inert to the paper (no acidity) - colours will last a long while. In theory. So if you demand archival quality, get a mortgage - or buy a new printer, which is often cheaper.
Meanhwhile on planet real world, for everyday printing on everyday papers, clone inks work just fine. I've used all kinds of clones, including those anonymous bulk carts from eBay suppliers - and have had no complaints so far. I print photos, which DRINK the cyan and magenta carts. I also avoid low-key images as they are all black ink.
You can try refilling your cartridges with a refill kit. This can save money. It can also turn into a total disaster darling!
Re: Printer inks
24-10-2013 5:55 PM
Quote from: Thunderclap I like Canon printers.
Funny you say that, I've heard many good things about their printers. I wanted the canon from Tesco with the doc feeder but my missus screwed up and got the HP
Re: Printer inks
25-10-2013 8:39 AM
Quote from: 7up it has many annoyances such as randomly disconnecting from the usb and reconnecting.
From my experience, USB discontent is often down to the connectors not quite making contact. Just touch the connector and the line drops. A shaking printer will wobble off the connection. Tried another lead?
Canon printers have stable software drivers. As for the carts, that's where Canon makes their money. But not from me. FYI I have purchased bulk carts from GoInks through eBay.
Re: Printer inks
25-10-2013 3:35 PM
The next 2 printers were Canon ip4500 followed by Canon MP610 both were excellent and I have still got them, always refill my my own cartridges using the original canon cartridges, these can also be reset using a Redsetter, I also refill using the German method and use top quality inks.
You need to do the research but details about everything I have mentioned and more is available on the following website,
http://www.printerknowledge.com/
Re: Printer inks
25-10-2013 3:41 PM
Re: Printer inks
25-10-2013 4:18 PM
I replaced it with an Epson WF-3540 which is performing well and satisfactory for my needs.
It is loaded with compatible cartridges.
Strat ducks to avoid the flak
Re: Printer inks
26-10-2013 4:57 PM
Must admit I have had to purchase 2 replacement print heads, fortunately for me the ip4500 and MP610 take the same print head so if something goes wrong I can check if it's the print head or not.
Quote from: Oldjim I have an IP4500 and I was so pleased with it that when it started suffering from apparent blocked nozzles - I say apparent as a full clean including immersing it in propyl alcohol didn't fix it - I bought a new head
Re: Printer inks
27-10-2013 12:42 PM
Re: Printer inks
27-10-2013 11:00 PM
Quote from: gleneagles The next 2 printers were Canon ip4500 followed by Canon MP610 both were excellent and I have still got them
Lucky git! I was going to get the MP610 but the delivery time was 3 days and I needed a printer on the day I bought the epson. I made a serious mistake there. The cannon had tons of 5 star reviews too so you can imagine how annoyed I was with myself..
Re: Printer inks
28-10-2013 2:44 PM
The Older ones had a steel rail which the printer head moved along but I understand the modern ones have a plastic rail and some users have commented that this is the cause of some problems.
A Few years ago there was a Canon outlet that sold refurbished printers including the MP610 and ip4500, they were selling for around £60 but included a new printer head and a set of New Original Canon cartridges, even if the printer turned out to be duff it was still an excellent bargain as printer head and inks would set you back around £100. Sadly I did not invest in one. They advertised through e-bay but they don't seem to be around now.
