Print Server
Print Server
Hi
Does anyone know of a half decent, and one that dosnt break the bank, print server, thats compatable with a Canon iP4300.  Looked at the mini netgear, but it does not appear to be compatable. Dosnt have to be wireless.
Re: Print Server
Any one would do Jetdirect is one of the best but unless you are doing masses of printing any will do. Often you get um on car boots for £2 as people dont know what they are
MuppetGrinder
Re: Print Server
Try a D-link DP-301U.  It's one of the cheepest USB to 10/100 print servers about and it has a small footprint so you can tuck it out the way Grin
p_w_d_stone
Re: Print Server
We have reliably used the DP-301U for tens of thousands of prints on three different printer models from three different manufacturers.
