Powerline Wired and WiFi improvement
FIXED- Subscribe to RSS Feed
- Re: Powerline Wired and WiFi improvement
23-09-2020 11:41 AM
Over the last few months, I've been expanding the Powerline network and wiring in computers, that were using WiFi for MS Teams, Skype and Google Meet. This has all worked well and has greatly improved PC and meeting performance
Oddly, it has also improved the WiFi on other devices Is this normal and expected, by doing this process?
Fixed! Go to the fix.
23-09-2020 11:50 AM
If all devices are using the same WiFi band and that's got limited bandwidth then most certainly. You can only use that bandwidth once regardless of how many devices are using it so they have to share.
24-09-2020 1:17 PM
@Baldrick1 I'm using both 5ghz and 2.4ghz and both have improved on the BT Hub6 🙂
My thought was being hardwired, may save computer effort and time in searching and validating for WiFi signal as those devices are just on tap:-), so the quality of the WiFi signal from the hub, has less competition and less takers?
24-09-2020 1:40 PM - edited 24-09-2020 1:41 PM
Once you boot a device, be it wired or wireless, it will establish a connection and lock onto that until it's switched off. So that's the searching and validating done.
If you're connecting to an Ethernet port the router is capable of handling up to 1000Mbps, although you are very unlikely to get anywhere near this with powerline units in circuit. Think of it as a pipe with all these bits flowing through like water through a pipe.
With wireless the data rate will be much slower or in other words the bits are flowing through our alternative imaginary wireless pipe at a much slower rate. How fast will depend on the band, the distance and the capability of connected devices.
Now if this wireless 'pipe' has several devices connected to it then regardless of how fast each device is the wireless bits all have to flow down this narrow restricted pipe, hence there will be a slow down in wireless performance of connected devices.
So taking some devices off wireless and transferring them to a faster Ethernet channel helps all devices.
Does this make sense?
24-09-2020 1:54 PM
@Baldrick1 Thank you 🙂 That explains and clarifies the whole process in clear plain English I'm now much wiser
