Power line adapters
Fixes: 5
Power line adapters
Does anyone know where I can buy single power line adapters. I currently have 2 tp link PA4010 devices but need a third. I cannot find anywhere that sells single units apart from used ones on eBay. Everywhere else sells just starter kit.
8 REPLIES 8
Fixes: 12
Re: Power line adapters
you can find almost anything on ebay but even a single powerline adapter might be a challenge!
Fixes: 370
Would this be of any use?
Forum Moderator and Customer
You can get a pair of them for less here:
https://www.amazon.co.uk/dp/B01BECPIMC/
Fixes: 5
Looks like I'm going to have to get 2.  Don't need the functionality of a wireless one really. Shame nobody does singles anymore, of the basic ones, except used on eBay. Thanks for the advice......
Fixes: 99
Why tne aversion to buying second hand from EBay? I imagine that there are many like me who have found that,satisfactory operation is dependant on the particular domestic wiring layout etc. and dumped them in favour of installing Ethernet cable.
Fixes: 5
@Baldrick1   I don't have a particular aversion to buying used tech from eBay, I've just been burned a couple of times, with stuff not working and the hassle of returning.  To be honest I am in your court, and prefer wired Ethernet to anything. My sky box us direct wired to the router via a gigabit switch. It's unfortunately just not feasible in my house to wire everything Ethernet.
VileReynard
Champion
Fixes: 17
I have several doing nothing in a dark cupboard.
I got fed-up continually crawling to reset the damn things.
Got majority stuff connected via Gigabit switch - including TV. 🙂
quelquod
Based on my experience there should be lots of single ones lying about somewhere. I've had 3 'starter kits' to connect up to a hard-to-reach corner of my house and each one has failed (only 1 end of course) after some months of intermittent usability and continual resets. I think they're a load of kack!
Democracy - 3 wolves and a lamb voting about what to have for lunch!
