Posting .pps on forum (solved)
I have a Power Point file that I want to share on my forum but it is too large.  I therefore want to link to it and tried this with my Photobucket account but this won't allow the .pps file (doesn't recognise it).
Please can someone tell me what is the easiest way to provide a link please?  Instructions too would be very much appreciated.
All sorted now - have used the Dropbox Public Folder and it seems to have worked well. However, any other suggestions welcome.
For any doggie fans here it is:
http://dl.dropbox.com/u/15703568/DogsAndPeople.pps
Re: Posting .pps on forum (solved)
My son put me on to drop box for on line storage and sharing - not bad, and by recommending it to other people, you can increase your free storage allocation  Smiley
So if you'd like to follow this link  http://db.tt/34I4tNq ; ....... Roll eyes
I started using Dropbox when first experimented with Linux as Hairy Biker suggested it for linking different operating systems.  Couldn't get on with it and eventually packed it in as a bad job.  Then I went back to it several months ago and now find it useful.  I don't put everything into it, just certain bits and pieces.  I'm not sure about putting all of my stuff into it (although there is not much) because when you open up the Documents or Pictures folder there is nothing there as they are all tucked away in the Dropbox folder.  Anyway, it has its uses, this being one of them.
