Possible Nvidia driver issues with Windows 10 upgrade?
- Possible Nvidia driver issues with Windows 10 upgr...
30-07-2015 9:47 AM
Quote from: NoZephy @PitchBlack
This might be seriously useful, I use it on every new install of Windows or any time I have to uninstall display drivers.
https://forums.geforce.com/default/topic/550192/wagnard-tools-ddu-gmp-tdr-manipulator-new-cpu-core-a...
The tool boots into safe mode and uninstalls the display driver for you but at the same time it stops windows and windows update from automatically applying a different version of the display driver automatically.
I had an issue before where whenever I would uninstall Nvidia's driver and reboot it would keep re-installing older versions of the Nvidia driver as soon as I booted up. So annoying but thanks to this tool it stops it from happening completely.
The above driver appears to be giving issues with some Win 10 upgrades, and the discussion seems to be at risk of getting lost in what is already a 40 page 'parent' thread (and likely to get much bigger, I suspect.)
I'm running Win7 64 on an HP Pavilion desktop, and the following driver update offered as an option via Windows update repeatedly fails to install:
nVidia - Display - NVIDIA GeForce 6150SE nForce 430
Installation date: 30/07/2015 08:31
Installation status: Failed
Code 80070103 Windows Update encountered an unknown error
Apart from that, when I run Geforce Experience it updates itself, and then closes, although its .exe file still shows as running in task manager (and refuses to 'end process') - so I uninstalled it altogether.
No actual problems that I'm aware of with the current drivers, but I'm struggling to get my head round this issue, and wondering whether the above is typical behaviour and likely to cause problems when I do upgrade (won't be for a while even when I do receive the download, which is currently 'We'll let you know when the upgrade is ready to be installed on this PC. Learn more. (clickable link but it doesn't actually do anything!
Re: Possible Nvidia driver issues with Windows 10 upgrade?
30-07-2015 12:34 PM
have you tried to DL from here instead http://www.guru3d.com/files-details/geforce-353-62-windows-10-driver-download.html ;
30-07-2015 1:41 PM
30-07-2015 2:15 PM
Phil
Using a TP-Link TD-W9980 modem-router.
30-07-2015 2:49 PM
I think there must be plenty of these chipsets out there on Win7 machines potentially just waiting to spring a surprise on would-be upgraders - another reason not to be in too much of a hurry to install it (or perhaps MS will deem my PC 'unsuitable' after all.
31-07-2015 10:22 AM
Quote from: JayG ...or perhaps MS will deem my PC 'unsuitable' after all. )
Confirmation wasn't actually hard to find having clicked on the Win 10 task bar icon (see attachment - love the suggestion in the bottom left!
Not a lot of joy for the many lumbered with the NVIDIA GeForce 6150SE nForce 430 integrated graphics chipset - not sure I'm desperate enough to try the workaround, and even less sure I want to start messing around with a new graphics card and probably PSU, configuration settings, and heaven knows what else:
https://forums.geforce.com/default/topic/860353/geforce6150se-nforce430-windows-10-display-driver/?o...
31-07-2015 12:40 PM
Phil
31-07-2015 1:17 PM
Time for patience I think - I'm sure there will be many similar problems arising in the near future, and who knows, maybe even some official support and fixes..
31-07-2015 2:10 PM
On running it tells me that Windows 10 cannot be run on my HP PC because NVIDIA GeForce 6150SE nForce 430 is incompatible / there are no supported networking devices (I have nVidia nForce 10/100 ethernet)
I looks like I may be running Windows 7 until my computer expires. It is old enough not to want to spend on updating the hardware.
31-07-2015 3:49 PM
Phil
01-08-2015 10:15 AM
Quote from: PeeGee You could try a 1GB GT610 "silent" PCI-e x16 card (less than £30) if you have a free slot. It is rated at 1W less than the G210 "silent" I have and both "require" a 300W PSU, according to nVidia. That assumes the series is Win 10 compatible
Phil
At least one person has had difficulties persuading Win10 that they have deactivated the on-board nForce 430 and are using the GT610 instead (post #14):
Although the GT610 seems like good value, especially if it does work with Win10, as a non-gamer it goes against the grain to be forced to pay for an otherwise unnecessary hardware upgrade to make what is supposed to be a 'free' Windows upgrade work properly - at 5 years my PC is not exactly ancient, although the nForce 430 chipset originated a few years before that I believe.
01-08-2015 11:43 AM
I have not tried to update the system, though.
Phil
02-08-2015 6:06 PM
Quote from: PeeGee I have not tried to update the system, though.
Have you tried the update yet?
(Go on, you know you want to, and you know I really want you to too!
02-08-2015 9:45 PM
That sounds worse than I was thinking
On the other hand, what are the chances of overwriting a single partition Win 7 with the three partitions and getting the unchanged "BIOS" boot sector run the replacement Win 7? Both systems boot the first partition.
Phil
02-08-2015 9:59 PM
http://www.z-a-recovery.com/download.aspx
There is a free one that should recover photos. I bough the full one some time ago (it was quite a bit cheaper then) and it's been a godsend on several occasions
