Port forwarding not working
- Port forwarding not working
13-04-2013 3:07 PM
Hi i have a whs 2011 with ports 80 & 443 set up to forward the device has a static ip with the subnet & gateway set correctly i can remote desktop into it from a client pc on the same lan and browse the web from it but cant set up port forwarding on it for remote access.
Any ideas?
Robert
Any ideas?
Robert
2 REPLIES 2
Re: Port forwarding not working
15-04-2013 10:31 PM
Had to reset dns today don't know if that has anything to do with it but still not working
17-04-2013 8:06 PM
Forget it ditched this pile of xxxx with all the problems i have had and plugged in an old billion router and evcerything works as it should, so anyone else reads this in the future ditch the router
