Port Forwarding not working correctly
- Port Forwarding not working correctly
28-10-2016 9:55 PM
Hi
Can anyone help me please.
I am trying to connect to a CCTV system via my phone and have been set up on the relevant app. I have set up port forwarding and opened the ports to make the CCTV playback feature work. They seem to work for a short period of time (about 10 mins) then port closes and I have to log back into the advanced port forwarding feature on the broadband router and reconnect.
I am not technical at all but would appreciate some help.
Re: Port Forwarding not working correctly
28-10-2016 9:56 PM
I have been allocated a static IP address but this doesn't seem to stop the problem.
28-10-2016 10:16 PM
You realise the mods will move this topic to the tech forum... you've posted it in general chat lol.
No idea but if it's a plusnet router don't get too hung up on the idea of reliable port forwarding. Plusnet supplied routers have a tendancy to be a bit hit and miss.
28-10-2016 10:22 PM - edited 28-10-2016 10:23 PM
Thanks 7Up, didn't realise there were different forums, new to all of this!
I thought that may be the case, so I will look to buy one, are all routers compatible with Plusnet?
Are there any that I should look at?
Thank you
29-10-2016 12:39 AM
Any 3rd party router is compatible with plusnet - electronic communication between your computer / router and the ISP (plusnet) uses protocols that are common to all ISP<>Router communication.
What you will need to do though is make sure you get the correct type for your connection - if you're using adsl then you want a adsl / dsl router. If you're on a fibre connection then you want a fibre router - etc.
Can't comment on the best, worst etc... I don't have enough experience with them all. I've only ever bought one router new - a cisco thing from pc world. Super reliable but it didn't show stats or have any advanced features.. but cost £96! I'd never pay that much again...
